So my 0.9" never stood a chance?warmstrong1955 wrote: ↑Sat Jan 11, 2020 4:41 pm
4" and up....
Less than that, you aren't going to get a .005" shrink.
2" bore....I have got up to .002".
heat shrink fit
Re: heat shrink fit
- warmstrong1955
Re: heat shrink fit
whateg0 wrote: ↑Sat Jan 11, 2020 5:05 pmSo my 0.9" never stood a chance?warmstrong1955 wrote: ↑Sat Jan 11, 2020 4:41 pm
4" and up....
Ummmmm.....no.
Re: heat shrink fit
Sure, but I'm interested in the case where a bore was smaller with the entire piece hot than it was when cold before you started.warmstrong1955 wrote: ↑Sat Jan 11, 2020 3:58 pmI've cheated oversize bores for years, just by heating them, uniformly, and then letting them cool on their own.John Hasler wrote: ↑Sat Jan 11, 2020 2:46 pm I understand that. I'm interested in the case where the hole shrinks when the entire part is heated uniformly as Bill reported.
Most I have done, were with larger bores, and done correctly, you can shrink them up to .005", and pretty much still round.
Bill
Re: heat shrink fit
500 F should get you .005" on a .90" hole in aluminum.whateg0 wrote: ↑Sat Jan 11, 2020 5:05 pmSo my 0.9" never stood a chance?warmstrong1955 wrote: ↑Sat Jan 11, 2020 4:41 pm
4" and up....
Re: heat shrink fit
One thing I considered after looking at Liveaboard's post at the top - that red hot block is going to transfer quite a bit of heat into the shaft. The block is then going to shrink, with the shaft being the last to cool. I think it's quite possible the shaft will be "shrunk" by this, leading to less interference than planned.
300 degrees will get you .002 in a 1" dimension. And that isn't hot enough to deform the internal part.
https://www.utausa.com/metalconverter.html
- liveaboard
Re: heat shrink fit
For that application, deformation was allowable and expected. But it's beyond by abilities to discern.
I had a slight taper cut into the end of the shaft and whacked it in quickly with a large hammer.
The bolt heated up very fast; but didn't appear to achieve red heat.
On cooling it seems suitably stuck.
I used an online calculator for heating this ring to fit over the hub. The 4" hoop only needed a couple of hundred C supposedly.
It should have just slipped on, but even though I used more heat than specified there was some interference.
Fortunately, I was ready with a hammer and had something below to hit against.
Next time I do something like this, I'll use a lot more extra heat. Hammering thin hot parts as they shrink and bind isn't really nice.
Anyway, the part did its job.
Re: heat shrink fit
I use the press in preference to a hammer whenever possible. I ruined too many parts with a hammer.
Re: heat shrink fit
When all you have is a hammer, everything looks like a nail! Seriously, though, when time is of the essence a quick blow from a hammer might seem preferable to the relatively slow action of a press. If I had to choose between a fast arbor press and a hydraulic press for this, if still think the about press a better choice. In my case, it didn't have enough oomph though.John Hasler wrote: ↑Sun Jan 12, 2020 11:22 am I use the press in preference to a hammer whenever possible. I ruined too many parts with a hammer.
Dave
Re: heat shrink fit
The way I do is turn to a shrink fit size, heat the female and freeze the male. You can never get it all the way through without the pin heating up and expanding. Work quickly and have a bloody big hammer handy. A vice will often help if a hammer is not desirable.
Re: heat shrink fit
A hammer is never desireable but it is sometimes necessary. I often used a vise before I got my Dake. I find that if I have properly designed and set up my fixture, gotten my temperatures, soak times, and clearances correct, and work quickly the part always goes in smoothly.
Of course, pretty often I just cook the pin with the torch while holding it with tongs until it looks right. I usually get away with it.
- warmstrong1955
Re: heat shrink fit
You have to have a plan, and be ready.
I’ve dropped frozen bearing races into heated up bores, and had them slide right on in only to bounce up, and stick where they bounced up to. Doesn’t take long to lose the clearance you once had.
- liveaboard
Re: heat shrink fit
Now that's got to be aggravating!warmstrong1955 wrote: ↑Mon Jan 13, 2020 12:07 pm had them slide right on in only to bounce up, and stick where they bounced up to.
