Gorton 375 Grinder Spindle Disassembly
SteveHGraham
Post by SteveHGraham » Tue Feb 04, 2020 8:18 pm
Haven't been around for a while. Hope everyone is doing well. I'm here with a repair question.
I got myself a Gorton 375 tool grinder. Mine is one of the later ones with no oiler on the spindle. When it arrived today, I found that the spindle bearings were shot.
I got the spindle out of the machine, and I removed the front of the arbor. I got the pulley off the other end and exposed the bearing on that side. That's as far as I got.
The back of the arbor is still on the machine. I don't know how to get it off, and I'm afraid to put pressure on it until I do. Beyond it, there is a cylinder which looks like it would accept a hook spanner, which I have. Under the cylinder, there is a huge nut which looks like it would work with a face spanner with square pins, if I could find one.
The big nut looks like it has right-hand threads. I have no idea about the threading, if any, on the cylinder. I don't know what's holding the arbor on. The pulley on the other end was just pressed on, and the fit was not tight. Tapping it lightly with a hammer made it come right out.
Even if I find out how this thing is put together, I need some way of holding the shaft so it doesn't turn while I unscrew things, and I have to be able to do it without marring it.
I read that this machine uses common bearings, so if I can get the spindle apart, I should be okay.
Sound off if you have any clues for me.
