Tapping carbon fiber tubing
Steve S
Post by Steve S » Wed Feb 26, 2020 5:13 pm
Does carbon fiber wear tooling quickly ?
I'm on the fourth hole and believe the tap is worn out ...
Tap is a M21 x 1mm brand new .
I'm using Imperial sizing die wax for a lubricant .
Steve S
GlennW
Re: Tapping carbon fiber tubing
Post by GlennW » Wed Feb 26, 2020 5:47 pm
Yes.
jcfx
Post by jcfx » Wed Feb 26, 2020 6:51 pm
What GlennW said, I did a bit vacuum bagging carbon fiber and the best cutting tool was tungsten carbide grit
cutting wheels, but that has nothing to do with tapping.
For tapping could you use threaded inserts instead ?
They can be glued in with a structural epoxy, you would still have to drill for the inserts, .
mcostello
Post by mcostello » Wed Feb 26, 2020 9:40 pm
Maybe You need Metric sizing die wax instead! :)
Steve S
Post by Steve S » Thu Feb 27, 2020 4:07 pm
GOOD ONE ! LOL
Magicniner
Post by Magicniner » Mon Mar 16, 2020 2:02 pm
Tap make?
Tap Type?
Are you tapping the bore of Carbon Fibre tube?
If so why, and have you considered the impact of that on it's structural integrity?
SteveM
Post by SteveM » Mon Mar 16, 2020 2:33 pm
Years ago, my brother was a mechanic.
He had so many different spray cans of stuff that a friend joked that when he had his car in for work and my brother asked him to get him the car cleaner, he said that my bother yelled "that's the imperial one, I need the metric one".
10 Wheeler Rob
Post by 10 Wheeler Rob » Wed Mar 18, 2020 6:01 am
Oh yes graphite dulls tool steel cutting surfaces quickly, we used diamond coated carbide tooling for machining graphite like used to make EDM electrodes where I used to work.
Rob
Steve S
Post by Steve S » Fri Mar 27, 2020 4:52 pm
Tap make?
Tap Type?
HSS plug tap
I made a couple of carbon fiber shrouds for my pcp air rifles .
It's a modified Kral NP-03 in .177 , shoots a 9.57gr pellet at 910fps . Over 17ft/lbs energy
Magicniner
Post by Magicniner » Sat Mar 28, 2020 10:58 am
HSS plug tap
Looks great Steve!
I've been abrading the inside of CF tube and bonding in threaded inserts for barrel shrouds.
