Hi Guys, needed to make brass plugs with an internal 10mm Hex.
Made this rotary broach, the most difficult aspect was to grind the cutter without a tool and cutter grinder.
Improvised by using my mill drill, made a spindle lock and a jig to hold my die grinder and ground the tool, happy with the result although tedious cranking the "Y" axis by hand.
Home Made Rotary Broach.
Re: Home Made Rotary Broach.
Well done! It's amazing the things one can do with just a little imagination.
Thanks Harold, I thoroughly enjoy making things in my shop, especially now in these trying times, keeps the mind active.
Smart idea! I'll have to remember that!
- 737mechanic
I have been wanting to make one myself for years but have not got around to it. Good Job.
