Way oil!....outrageously priced!
earlgo
Re: Way oil!....outrageously priced!
Post by earlgo » Mon Jan 10, 2022 2:23 pm
Just checked McMaster-Carr and the 1 gal is $42 and the 5 gal is $176. However, both are "Temporarily Unavailable".
--earlgo
pete
Post by pete » Mon Jan 10, 2022 3:02 pm
Yes thanks for the link Pete. I've never used that Hangsterfers product but have seen the brand mentioned quite a bit on the PM forums. By all accounts that company is supposed to be pretty good and really knows what there doing. Who knows, it might even be better than the usual Vactra. Definitely a much more sane price for sure.
Inspector
Post by Inspector » Mon Jan 10, 2022 3:55 pm
QCT has a full range of stuff for machining. Cutters, holders, bits measuring tools, etc. All the goodies KBC and the like have and for me they have it within a day or two for pickup.
Pete
gwrdriver
Post by gwrdriver » Sat Jan 22, 2022 1:46 pm
Almost 40 years ago, because it was factory specified as a general lubrication for my British geared head lathe, I began using ISO-68 hydraulic oil on the ways and slides and that has turned out to be a great way oil in every way. 5-Gallons is now running between $60-$75/USd and is available at any Farm&Home and auto supply.
GWRdriver
Nashville TN
RSG
Post by RSG » Sun Jan 23, 2022 9:25 am
Good to know Gwrdriver!
ramsay
Post by ramsay » Sun Jan 23, 2022 12:50 pm
Walmart bar and chain oil.. Cheap and stays put.. Cheers from Louisiana
wally318
Post by wally318 » Sun Jan 30, 2022 7:07 pm
If you go to KBC's website they sell their EZE way and spindle lubes for 27.50 to 30.00 cdn/US gallon
and flat rate of 11.00 for shipping. So unless your really hung up on Vactra you can save quite a bit there.
And lets face it for most lathe lubes say: way oil anything in a way lube will do fine-just the viscosity
to think about. Same goes for grease nipples and ball oilers generic will do fine. Its more about lubing
often enough not so much the brand name.
When it gets to spindle oils things get a bit more specific, but mostly the correct visosity for the bearings
involved.
The only situation I know of where it gets very oil specific is in something like the Variator on a Chipmaster
lathe where there is only 1 type of oil approved for use-warranty and longevity.
Post by Bill Shields » Sun Jan 30, 2022 7:15 pm
I get it at tractor supply..
Inspector
Post by Inspector » Sun Jan 30, 2022 8:23 pm
As good as Tractor Supply may be, according to their website they don't ship to Canada. That doesn't do the original poster (RSG) any good as he lives in Ontario. Great for you gents under the 49th though.
Pete
Post by Bill Shields » Sun Jan 30, 2022 8:27 pm
Ah...guess they don't have tractors in CA :mrgreen:
mcostello
Post by mcostello » Sun Jan 30, 2022 10:03 pm
Canada is so cold 10wt oil just might substitute for way oil. :)
Post by Bill Shields » Sun Jan 30, 2022 11:40 pm
And they use Chain saws to cut holes in ice for fishing?
No wonder the bar lube works so well. :mrgreen:
