Po' mans electric shop heater
Here is a poor mans electric shop heater made from 2 dryer elements and a Jennair range blower. The thing is controlled by a low voltage transformer and a condensing unit relay with a wall thermostat. All junk parts and around 34,000 btu. It is mounted high enough that you would have to try to get something stuck in it. Good enough for me.
Can't quite get the image as good as I thought.
Re: Po' mans electric shop heater - Better Pic?
Couldn't get the external image link to work. I'll try to attach a different one here.
The Fire dept would like your address. :-)
[img]/ubb/images/graemlins/smirk.gif"%20alt="[/img]
Re: The Fire dept would like your address. :-)
This setup is way better than one that I saw in a shop once...
It was a "U" shaped frame on a pedistal with three 240 volt 1000 watt electrical switchboard heaters bolted to it and a box fan standing behind it... the wiring was open and the stand was a little wobbley... it did put out the heat thou, even from the cable supplying the electricity... [img]/ubb/images/graemlins/shocked.gif"%20alt="[/img]
[b]Bryan[/b]
[i]"Simplicity is the ultimate sophistication."[/i] Leonardo da Vinci (1452-1519)
That looks dangerous, but I kind of like it. Of course, I tried to build a fan out of a 3450 rpm motor by heating up some old plastic blades and pressing the hub onto the motor shaft when I was much younger. I believe it made about 3 revolutions before I began learning about such concepts as "balance", "stress" and "duck".
I do like solutions like the heater; simple, got the parts, makes you warm. There it is, done. And well, you shouldn't stuck your finger there, that'll learn you.
Rob
Rob
[b] Some days are diamonds....[/b]
you'll be "po" paying electric rates out here in Checkoslafornia (CA).....If I remember right my electric dryer pulls about 4.5 KW on one element.....Two of them puppies would make my meter vibrate!
Many times the fire dept does'nt need an address, they can see your address
From miles away!
Don't ask how I know that.
Indeed.
Gregg
If it really can produce 34,000 BTUs then it would be drawing more than 10 kilowatts from the line, which would be more than 45 amps. It's an expensive way to heat a shop, in my opinion. Of course, if the heater succeeds in setting the shop on fire you'll get a lot more than 34,000 BTUs in exchange for the 10 KW.
