VFD Help
VFD Help
Hi,
I a just learning about vfds and looking for some opinions.
I have a 17" Rockwell drill press with a 1hp 3 phase motor and would like to install a vfd. I am looking a Teco FM50.
I am also in the process of making a 12" disc sander with 1-1/2 hp 3ph 3450 rpm motor on it also. Looking to use a Teco FM50 on it also.
Will these do the job for me or do I need something else? I want to install a pot and start stop reverse switch also.
Thanks,
Dave
Thanks,
Dave
Dave
good choice
IIRC the difference between the fm50 and the fm100 is the latter includes the speed control pot. For the difference in price, is it really worthwhile setting up a remote operator panel?
If you're considering a legal installation with the unit in a large enough metal enclosure, which also protects it from chips, then the remote panel is kind of a must. But those of us who never invite electrical inspectors to our shops just hang the unit right on the machine and go for the included operator panel.
- Steve_in_Mich
Which TECO FM 50, there are a few.
I see they are quite reasonable here;
http://www.factorymation.com/s.nl/it.A/id.193/.f
And you can download the Specs. and Owners Manual at that site which should answer you questions.
Hi,
I am taking rohamm's advise and looking at the Teco FM100-202-N1 and also Hatachi L200-015NFU2 or X200-015NFU1. Any one know the difference in the L200 and the X200? I downloaded the manuals but don't understand a lot of the lingo. Just want it simple. Forward, reverse and adjustable speed for now. I don't know if I need a brake or not.
Thanks,
Dave
Thanks,
Dave
Dave
Ya know, this just shows me ya learn something new every day. I had no ideal a VFD could take 120V single phase and run a 230V 3-phase motor. Learned that by reading the specs on Teco50.
I'm fairly sure I have the TEC0100 because it has the speed pot. I took me 3 years before I new the speed pot was already there. I was about to wire up a speed pot and the manual said the little black knob was a speed pot. The Teco 100 needed to be programmed to activate the speed pot.
This old drillpress with the Teco 100 VFD is a geat setup. Electrically variable speed and reversable from a foot switch for tapping. The drive belt is used only when more power or speed is required. Had the Teco VFD for 6 years now and love the thing. It came from Dealer Electric and paid $180 for it back in 02
Jim
Jim
www.outbackmachineshop.com
- tornitore45
vfd
sharing a VFD must be done very carefully.
most of the drives are set up for specific size motor, and if you change motors, some require reprogramming.
Also, you generally DON'T want to disconnect the VFD from the motor with power on - so if you share, you need to have the control located so that you can get at it for all machines.
In general, I would say that sharing a drive amongst multiple motors is possible, but annoying to implement.
Brakes really aren't needed unless you have an application that needs quick start / stop for one reason or another.
Having a brake on a lathe can be really nice - if the transmission (belts) can handle the reverse torque - most flat belt drives have problems with rapid braking - tends to pop the belts off. V-belts and gears are generally OK.
- Steve_in_Mich
Jim maybe you want to add this to the learning curve. There are also 220 single phase capable input VFD's with 480 3 phase output and I run one wood lathe I have (5 or 6 years now) with a 115 volt single phase input VFD that puts out 115 volt 3 phase to a 115 volt 3 phase 1 HP inverter matched motor.JimGlass wrote:Ya know, this just shows me ya learn something new every day. I had no ideal a VFD could take 120V single phase and run a 230V 3-phase motor. Learned that by reading the specs on Teco50.
I didn't know that either Sometimes I stop the drillpress with the original ON/OFF switch for a quick tool change. I'll stop doing that.you generally DON'T want to disconnect the VFD from the motor with power on
I know this also applies to steppermotors
Jim
Dave, check with dealers electric http://www.dealerselectric.com/
I've purchased a couple teco 100's from them.
brent
brent
Disconnect
Generally, it is not a good idea to cut the cable between the drive and the motor when the motor is spinning.
While this often goes unsaid, take a look at any of the provided schematics and see if there is a switch shown anywhere between the VFD and the motor.
I know one fellow on another board who went through several drive units because he was interrupting the circuit, and every time he did, he blew up the drive.
Some are better than others about handling the 'disconnect' - some totally intolerant. Sorry, I don't know which is which - since I don't recommend disconnecting any of them under load.
