Vortex canister design
- steamin10
No, filters are filters, and a separator separates. Filters clog and must be cleaned or changed. Separators just get full.
In the cyclone style I have been told a hardware cloth at midlevel really helps to keep small particles from blowing out. Shaped like a shallow cone toward the center outlet it allows particles to fall through into a quiet air zone and fall to the bottom . In my case with wood sawdust it is a half inch variety. Obviously it wont work for the planer as the chips are large, but then I just remove the screen and I am ready to go. There is vitually no sawdust in planer chips, just some fuzz.
Use an oiled foam prefilter
As discussed above, the strategy to extend filter life is to remove as much dust and debris as possible before it hits the final filter.
Where I work, we have the same problems with air filters in small engine applications. One of the most effective ways to extend filter system life is to use an oiled foam prefilter. The foam openings are huge compared to the dust particles that are collected. With an oiled foam prefilter, the dust sticks to the oil as it passes through the foam, but the openings are large enough that effective life of the filter is quite long. The oil wets the dust particle and the particle becomes the new collecting surface. When the foam prefilter finally clogs, you wash it with detergent, re-oil and start over.
Typically mixing oil, saw bar oil or engine oil work on the filter, but in situations where use of mineral oil is environmentally bad, I have seen non-drying vegetable oils, such as peanut or olive oil used to oil the filter.
