I need some mathmatics help! (Wife says that ain't all)
Ridgerunner
Post by Ridgerunner » Thu Jun 26, 2008 9:37 pm
I have Googled and Yahooed my butt off trying to find out how to obtain the length of an arc with a known angle and known radius. I now feel dumber and more confused than when I started!
O.K. here it is: angle = 24degrees; radius is 26. Can anyone give me the formula to find the length of the arc?
I have had enough of reading about radians, subtending angles, moments and etc., all I want is the stupid FORMULA so I can work it out on my own. You guessed it, math was my Achilles heel in high school and what trig I know is self taught as an old fashioned draftsman (pre AutoCAD).
Thanks for any assistance.
Gary
kenh
Post by kenh » Thu Jun 26, 2008 9:46 pm
GlennW
Post by GlennW » Thu Jun 26, 2008 9:49 pm
Ridgerunner
Post by Ridgerunner » Thu Jun 26, 2008 10:01 pm
Thanks Kenh, that's just what I was looking for. This place is great - ask a question and some kind soul answers in 9 minutes - love it!
Wow Glenn, it doesn't come any easier than that!
Thanks guys,
Gary
GlennW
Post by GlennW » Thu Jun 26, 2008 10:24 pm
In simple "machinist's" terms....
Looks like it would be the Sine of 24° X Radius!
Seems simpler than the formulae they show.
poohbear2767
Post by poohbear2767 » Fri Jun 27, 2008 12:03 am
Glenn Wegman wrote:In simple "machinist's" terms....
Actually that would equal the CoSine.
You need to convert 24 degrees to Radians then multiply times the Radius.
24 degrees = .41887902 Radians.
.41887902 Radians x 26 inches = 10.89085452 inches
Pooh Bear
Skeeter5000
math formula
Post by Skeeter5000 » Fri Jun 27, 2008 2:16 am
I am not a math wizard, just another way to work this.
radius = 26 makes the dia. 52.
52 x 3.1416 = 163.3632
163.3632 / 360 = 0.4537866
0.4537866 x 24 = 10.890878
Glad you found the answer
toastydeath
Post by toastydeath » Fri Jun 27, 2008 2:37 am
I had written some stuff proving why radians and also the equations on the websites. Until I accidentally unplugged my computer. Oh well. If anyone's interested, I can do it again.
Long story short, you can't use sine/cosine to do arc length. Also, the equations on the first webpage is correct, and the shortest. If you have a shorter way, it's probably not right.
GlennW
Post by GlennW » Fri Jun 27, 2008 5:01 am
Thanks for the correction guys.
I was thinking that my "method" would give you the distance in a straight line rather than an arc, but when I used a conversion calculator to convert one Degree to Radians the answer it gave was 0.01745329 which I thought was also the Sine of 1! Didn't read enough decimal places though! :oops:
Doing other things at the same time and not paying enough attention!
That's where my assumption came from.
hj-meyer
Post by hj-meyer » Fri Jun 27, 2008 5:33 am
This calculator is also easy to use:
HS-Rechner
http://www.hs-rechner.de/bits_bytes.htm
Hans-Jürgen[/img]
GearGeek
Post by GearGeek » Fri Jun 27, 2008 5:58 pm
I like that one! pitty I don't see a mac version :(
I can read german pretty decent but I can't speak much.
Viel Spaß!
~GearGeek
machine48
Post by machine48 » Fri Jun 27, 2008 8:23 pm
radius x angle x pi/ 180= arc lenght
