Reguarding TuroCAD
Posted: Tue Nov 17, 2009 11:38 am
The version I have is Windows version 3.01 copy write 1985- 1996 by ISMI.
It will let you draw to size and print to scale or go the other way too. I all ready knew AutoCAD some so tha tmay hav ehelpped the pick up.
The thing I like best about it, other than i paid like $30 bucks retail for it is with todays printers, you get really acurate pint outs, and can even print on trasparency film for templates.
I got dial crank mills and often will put a template on top of work to show me if I turned the right number cranks turns. Saves a lot layout time and erros.
For one or two off radial bolt paterns, I jus due them on the cad and then X & Y dimesion, to save time setting up the rotary table.
For non critical shapes in sheet stock, glue a print on with wood glue, saw and sand, then soak the print and glue off in warm water.
Rob
Rob
