Im looking for plans for a gryoscope
Back in what us old farts refer to as 'the good old days', the gyroscopic instruments in our aircraft had gyroscopes driven by vacuum. Normally the vacuum was provided by an engine driven pump, but an emergency backup source was provided by the use of a venturi mounted on he outside of the fuselage. After landing and engine shutdown, you could hear the gyroscope running for what seemed like ages. Possibly, you could scour some of the older surplus stores a find one of these instruments to use as a model.
Vacuum
Driven BY a vacuum or operating IN a vacuum?
IN a vacuum is one of the things Sperry did back in 'old fart' days
Re: Im looking for plans for a gryoscope
If I remember correctly, there were little "cups" on the rim. Should be pretty simple with end-mill cutter.
--Bob
Once you get your gyroscope built, see if you can make it into a gyrocompass. The concept is described here...
http://ed-thelen.org/SperryManual.html
Regards, Marv
Home Shop Freeware
Home Shop Freeware
737mechanic
Very Cool Father Son Project..
These might be of Interest:
The Gyroscope 1958 (269p)
https://archive.org/details/TheGyroscope
Effects of angular vibration on the performance of a single
-degree -of-freedom integrating gyroscope 1960 (236p)
https://archive.org/details/effectsofangular00haff
Problems of rotary motion presented by the gyroscope, the
precession of the equinoxes, and the pendulum 1873 (94p)
https://archive.org/details/problemsofrotary00barnrich
The Sperry gyro-compass 1920 (60p)
https://archive.org/details/sperrygyrocompas00sperrich
Spinning tops.
The "Operatives' lecture" of the British Association
meeting at Leeds, 6th September, 1890 -1910 (172p)
https://archive.org/details/spinningtopsoper00perruoft
An elementary treatment of the theory of spinning
tops and gyroscopic motion 1909 (170p)
https://archive.org/details/elementarytreatm00crabiala
Physics I- Classical Mechanics -
Two Dimensional Rotational Kinematics 1910 (21p)
https://archive.org/details/flooved3307
EDIT/UPDATE:
FREE Gyroscope Plans and Info
http://www.gyroscopes.org/forum/questions.asp?id=790
http://www.gyroscopes.org/propulsion.asp
http://aeroquad.com/content.php?s=d7077 ... 5e6d72d991
http://ultralight-airplanes.info/gyrocopters.com
Enjoy.
Ken.
Spinning tops.
EDIT/UPDATE:
Enjoy.
Ken.
One must remember.
Ken.
Ken.
- refinery mike
I had a relative who made a gyroscope out of the flywheel off of a hay bailer. Then he cut up a car to put it in. It only had two wheels side by side. The gyro kept it up when it moved. Not practicle for anything but parrades. but a real attention getter.
I don't suppose you have pictures of that car, do you Mike?
That scares me just thinking about !refinery mike wrote:I had a relative who made a gyroscope out of the flywheel off of a hay bailer. Then he cut up a car to put it in. It only had two wheels side by side. The gyro kept it up when it moved. Not practicle for anything but parrades. but a real attention getter.
Sounds more like a flywheel-inertia-propelled car than a gyroscope.
Mikerefinery mike wrote:I had a relative who made a gyroscope out of the flywheel off of a hay bailer. Then he cut up a car to put it in. It only had two wheels side by side. The gyro kept it up when it moved. Not practicle for anything but parrades. but a real attention getter.
Can you make a video of it, and Share It With Us
Ken.
One must remember.
Ken.
Ken.
Live for the moment!
Prepare for tomorrow!
Forgive the past!
Forgive the past!
Good Morning PatPatio wrote:A gyro car!
http://www.aqpl43.dsl.pipex.com/MUSEUM/ ... hilovs.htm
Very Cool Find
Ken.
One must remember.
Ken.
Ken.
