Page 1 of 1
Spanner Wrench
Posted: Sun Sep 04, 2011 10:29 am
by gregrycm
Hello,
I decided to build my own spanner wrench after ordering one that was the wrong size. It was a pretty quick project and except for the welding, I am happy with the resulting tool.
Here are a couple of 'before and after' MIG welding photos:
My intentions were to fill the holes with weld, then file. But the web at the hole edges was too thin and some of that metal melted away. So this is the result after lots of filing.
Handle and Body 2 by gregrycm, on Flickr
Welded by gregrycm, on Flickr
I thought about drilling smaller holes in the same location and pinning, but I was concerned about things loosening after some use. Any suggestions for the next tool that I might build?
Thanks,
Greg
Re: Spanner Wrench
Posted: Sun Sep 04, 2011 12:02 pm
by CraigS
Nice job,
I need to build on of theses for my lathe. How about, instead of welding just using some hard pins press fit in the holes.
Craig
gregrycm wrote:Hello,
Thanks,
Greg
Re: Spanner Wrench
Posted: Sun Sep 04, 2011 12:22 pm
by gregrycm
Craig,
I thought about pinning, but was not sure if the holes would loosen up after some use.
Greg
Re: Spanner Wrench
Posted: Sun Sep 04, 2011 9:38 pm
by Davo J
I do a lot of this sort of wig welding myself, where you want it to look like it wasn't welded.
For this I would have drilled into the flat of the spanner and plug welded that side instead. This way it would have been easier to finish to the flat surface instead of the round.
Getting the wire speed and heat right are important as well, so it's best to have a practice on a piece of scrap. With todays electricity over here welding delicate stuff, one setting on the welder at lunch will be a lot different at night etc, so it needs adjusting at the time your doing it.
Still a nice job on the spanner.
Dave
Re: Spanner Wrench
Posted: Sun Sep 04, 2011 9:43 pm
by Davo J
I forgot to add,
If there is room, I usually drill the hole with just the end of the drill bit so the sides are tapered. This way it lets you get the mig wire in easier.
Dave
Re: Spanner Wrench
Posted: Thu Sep 08, 2011 1:22 am
by John Hill
Thats a very nice looking tool.
I might be a bit old fashioned but for fixing something like that I usually rivet it. If carefully done the result can be almost invisible.
Re: Spanner Wrench
Posted: Wed Sep 21, 2011 5:36 pm
by norman
Why not pin and silver solder? Ooop! Looks like you used tubing instead of a steel rod for the handle or did you? Still the tool looks fine to me the way you did it, if it works good that is what matters.
Re: Spanner Wrench
Posted: Sat Sep 24, 2011 5:28 pm
by flutedchamber
Two 1/8 or 3/16 roll pins would have worked fine. Plenty of strength. There are a lot of different ways to skin this cat.
Fine job.
