looking for cast iron tubing
looking to find machinable cast iron tubing 4or 4.5 " id and 8" od, no smaller than 7.5 though and no bigger than 5" on the id. anyone know where to purchase something like that or do i have to get bar stock? thanks josh
Re: looking for cast iron tubing
The only cast iron "tubing" I've ever seen was sewer pipe. That is very thick wall for any of that.
What in the world is that going to be used for??
...lew...
...lew...
check these guys out:
http://www.dura-bar.com/sizes/tubes.cfm
one of their distributors might offer "cut to length".
hope it helps, whatcha' working on?
You might check with Alro and see if they have a rem or drop. There usual length for durabar is 6'. It will cost a fortune, probably. I've used some durabar tubing but years ago. It is nice to machine.
http://www.alro.com/dataCatalog/017-Cas ... df#Page=14
JerryK
JerryK
I'd like to stumble across 2 foot of 14" diameter stuff...
It wouldn't be too expensive to make a pattern from wood and have an iron foundry cast it. Sewer pipe first came to mind, but it would only be available in long lengths and very expensive, if you could find it in the size you want.joshuaj97 wrote:looking to find machinable cast iron tubing 4or 4.5 " id and 8" od, no smaller than 7.5 though and no bigger than 5" on the id. anyone know where to purchase something like that or do i have to get bar stock? thanks josh
Mr.Ron from South Mississippi
