Howdy all. I'm looking for a table that lists the coefficient of friction of numerous plastics. I'm designing a part that slides in an anodized aluminum bore. It has a plastic brake that expands in the bore slowing the part's rebound off a spring. The plastic would need good wear resistance as well as some friction against the aluminum.
Delrin has the right wear and hardness but is too slippery.
Thanks,
Dan
Coefficient of friction plastics
- warmstrong1955
Re: Coefficient of friction plastics
Take a look here:
http://machinist-materials.com/comparis ... astics.htm
There's a lot of info on the net. Mcmaster Carr also has charts on the properties of plastics.
Bill
Bill
The "Handbook of Chemistry and Physics" by CRC Press. Should be one in your local library.
...lew...
...lew...
Thanks for the help everyone.
This is for a hammer in an air rifle. I've made many and used abs plastic. I just made one for a new rifle model. The surface area of the brake is much reduced and I think it will work better if I could find a stickier material.
I can change the geometry of the parts to increase braking force as well.
Dan
Dan
