Hossfeld Bender Question
revrnd
Post by revrnd »
If anyone has 1 of these benders, could you tell me the dia' of the holes for the various pins? I'm reworking a generic version & it might be easier to adapt a Hossfeld part rather than attempt to make the part from scratch (heavy heating & bending req'd).
Thank you.
Lew Hartswick
Re: Hossfeld Bender Question
Post by Lew Hartswick »
I can measure anything you want Tomorrow when school starts. :-) You mean the pivot pin hole
and the row of holes on the swing arm???
...lew...
revrnd
Post by revrnd »
Lew Hartswick wrote:I can measure anything you want Tomorrow when school starts. :-) You mean the pivot pin hole
...lew...
Exactly!
Lew Hartswick
OK! The pivot hole is 0.777, for a 3/4" pin. The row of holes for the fixtures are 0.645, for 5/8" pins.
There two small holes at the ends of the row of 5/8 ones that measure 0.440 (no idea what they
are for)
Now to see if I can post a pix. :-)
Another try smaller size, was too big.
OK that works. Does that answer all the requirements?
...Lew...
revrnd
Post by revrnd »
Lew, thanks for checking. Unfortunately that makes the pins too large to work w/ my bender (5/8" dia holes). I think I've got a workaround to my dilemma though.
aametalmaster
Post by aametalmaster »
Lew Hartswick wrote: There two small holes at the ends of the row of 5/8 ones that measure 0.440 (no idea what they
are for)
...Lew...
Lew the .440 holes are for the 19b4 U Pin since it has a smaller pin on the end for the .440 hole. The regular U Pin has 5/8 on the shaft and on the pin end...Bob
Page 4 here has it. http://www.hossfeldbender.com/downloads ... endNo2.pdf
Bob Wright Metal Master Fab
Salem, Ohio
http://www.chaski.com
Flybynight
Post by Flybynight »
Interesting, I built my own Bender about 8 years ago.
But as I am getting older, I have had a hard time doing some of the bends.
So, I build a bracket (like the picture) to hold a hand jack like the picture to bend the heavy stuff.
Armed Men are Citizens, Unarmed men are Subjects.
