Sunnen Mandrel Sizes
NealinCA
Post by NealinCA » Thu Nov 21, 2013 5:55 pm
I have an old Sunnen pin hone, which uses SL style mandrels. I need to hone some 1-3/8" bushings. Can anyone sell me what number mandrel I would use? I don't have any in that size range, so I will need to find one. I just need to know what I am searching for, part number wise....SL-1xxx?
Here's a pic of the hone, circa 1932. I have since added a coolant tank and pump.
Thanks,
Neal
GlennW
Re: Sunnen Mandrel Sizes
Post by GlennW » Thu Nov 21, 2013 9:15 pm
Pretty sure I have one somewhere.
I'll check tomorrow.
Fact is, I could probably fix you up with a pretty good size box of SL mandrels and stones...
Steamin
Post by Steamin » Thu Nov 21, 2013 10:48 pm
Nice little hone! I have a bench top model which has the dial indicator on it, finding mandrels for it is the hard part!
If you are just looking for the numbers, I think this is what you need:
#1250 is range 1.230 - 1.375
#1375 is range 1.355 - 1.500
Steamin
NealinCA
Post by NealinCA » Thu Nov 21, 2013 11:25 pm
Thanks steamin...that helps with the numbers.
And Glenn...let me know if you have an SL-1375, I could also use an SL-1125.
Thanks,
Neal
GlennW
Post by GlennW » Fri Nov 22, 2013 2:47 pm
The sizes would be SL-1140, SL-1200, SL-1300, SL-1400, etc.
Got about 50 of those early style mandrels and some boxes of stones.
PM me if you are interested.
