I read this as Cincinnatti Toastmaster.Bill_Cook wrote:I'm the second owner of a pristine BP sized 1956 Cincinnatti Toolmaster.
Who uses a DRO, and who doesn't..?
Re: Who uses a DRO, and who doesn't..?
I tend to agree with you, Bill. Only a fool would determine a DRO isn't a valuable asset, but there's so many things a guy can buy with the money, allowing for other things to get accomplished, that I consider them a poor investment. If a guy lacks the necessary skill to run dials, or has more then enough money to purchase his needs, I certainly agree, they're a nice addition to a machine.Bill_Cook wrote:The price of a DRO could be better spent on shop capability, not on vulnerable electronic convience. (It would be nice tho.)
Still, when it's all said and done, I'm still damned proud of the fact that I can operate my machines without a DRO, and achieve the expected results. Of course, that was expected of us when I was trained. There were no DRO's.
Me too BC. I am the second owner of a full optioned 1B. I'm figuring a 1955 or 1956 (close) a couple of
small drill marks (NOT ME) Toolmasters great big mint dials. Back to the subject, yes I put dro's on it, next
the lathes. Why? If anybody in here operates example 1940's S Bends & shapers no matter what, the dials
are tottally worthless. I got enough problems reading yard sticks never mind a mic.....And then I was told
that somehow you can get into the readout and connect to a comp. monitor, now thats nice bill board size
numbers would be sweet. Whats next a seeing eye cat? the cat can see a fly 50ft away!!!
I have a DRO on my 3-in-1 and find it to be an invaluable crutch, for all the reasons listed above but also because it's darn near impossible for me to see or read the saddle dial -- it's small and hidden below the table. That said, I don't have a scale on the tailstock or the compound. I use the dials for those.
Of the features I use the most are the centering function and the Radius/Diameter function. The first is obvious. The second merely changes the way the measurements are presented. Radius provides a 1:1 measurement -- use that for most milling, and travel along the lathe bed. Diameter provides a 1:2 measurement -- useful for the lathe cross-slide, the mill spindle for vertical RT work (or other axis for horizontal RT work).
Another very useful trick is the bolt hole circle function. They don't have to be bolt-holes, either. I've made index plates for my rotary table with patterns that could not be achieved with the supplied plates and ran to 15 decimal places when calculated in degrees. Talk about opportunity for errors!
Given the cost of materials vs the reduction of errors, I think the DRO has paid for itself. The one draw back is that I am not proficient in the use of dials, so I would be at a disadvantage trying to use a machine that lacked a DRO. But then, I am a home hobbyist and only operate my own machines. It's not like I'm a professional who may be tasked with operating any machine in the shop.
DRO's are most useful in multiple tool operations, they give you the ability to change tools with different lengths/locations by using indicated dimensions. A poorman's CNC concept keep a cheatsheet and an established (0,0,0) for one tool part after part can be made to the same settings. This still requires verification that tolerances are being maintained. I've seen a 1,000 parts with a dozen or more feature done in free machining steel done on a single set up this way. Tedious but very cost effective in a small jobbing shop..
i have dro,s on a few machines but consider this we , this older generation have been trained to all things dial from a early age, be it watches, clocks, tachs, thermometer, ad nasuea but a youngster may well not be able to tell time in analog,know clockwise or where or how to cover your six. do math with out a calculator and soon how to write in cursive at all.
but can translate rolling digits with ease
I am a spread sheet fanatic...I have had to master a Excel at work, I find it pretty useful in the shop..
Don`t forget `spell`. Wnt b lng b4 txt is norm.hammermill wrote:i have dro,s on a few machines but consider this we , this older generation have been trained to all things dial from a early age, be it watches, clocks, tachs, thermometer, ad nasuea but a youngster may well not be able to tell time in analog,know clockwise or where or how to cover your six. do math with out a calculator and soon how to write in cursive at all.
I see you're post was entered at "20 of".hammermill wrote:this older generation have been trained to all things dial from a early age, be it watches, clocks, tachs, thermometer, ad nasuea but a youngster may well not be able to tell time in analog, know clockwise or where or how to cover your six.
BC
Having little more than tasted the power of Excel, it's easy to see how useful it could be all around the shop.AllenH59 wrote:I am a spread sheet fanatic...I have had to master a Excel at work, I find it pretty useful in the shop..
The ability of a CAD program to visually convert the dimentions of a part to travel distances including offsets for tool diameters with total math confidence has made it easier for me to live without a DRO or take MS Office past basic Word chores.
Not that it mattered in this case, but the edge finder in the lower left view is contacring the corner of the part after it was sliced in half, not the OD. In the upper left view the edge finder is contacting the theoretical sharp corner, but without any calculating it could have worked off a chamfer or radius.
The tool is for expanding the bottom of a Ball® 12oz beverage can to fit over another to make light weight alcohol stoves. Note the backpack in the pic below. Anyone here cruising I-81 between Harrisburg PA and Maryland is invited to stop in and follow this old man and his dog into the local 130 sq mile state forest, year round, on or off trail, day or night. I normally go out nights and Sundays, (especially during hunting season.)
http://www.pbase.com/lecook/image/153537520
BC
Hi There,
I've been trained on dials and used them for about 20+ years. About
10 years ago, I added an inexpensive DRO system to my mill and I have
to admit, I wouldn't want to go back to just dials BUT I could if the EMP
comes.
The debate over digital vs analog is a fair one. Digital, at a glance will impart
a greater sense of accuracy but analog imparts relationship better (IMHO).
Hence, the digital watch wearer says: "it is 6:45," where the analog watch
wearer says : "it is a quarter to seven."
Good Luck!
-Blue Chips-
Webb
comes.
Good Luck!
-Blue Chips-
Webb
- warmstrong1955
I learned with dials. I added a DRO to my lathe later, and my mill some time after that.
The lathe.....sometimes I use it....sometimes I don't. Probably 50/50 on the lathe.
The mill, more often than not. Very handy for hole patterns among other tasks.
Guess I'm ambidextrous?
Knowing how to use the dials, can be handy. No EMP hit my shop (yet), but I had a scale bite the dust in the middle of a project. No big deal....I dialed in and dialed away.
Bill
Bill
