Rotary table expansion
Previously I posted a question on setting up a RT and now here is how I fixed the problem: The RT I have is 6", so I took a piece of aluminum plate, 12" diameter and bolted it to the RT on spacers so it sits 3/4" above the RT top. I then milled 4 slots, 90° apart to accomodate tee nuts. I bolted it down using hex head bolts. I then took a skim coat over the bolt heads for a flat plane. The aluminum I used was a 7000 series aircraft alloy. I won't be doing much work on steel; mostly aluminum. 3/8" would have been sufficient for spacers, but I had 3/4" stock on hand. If I come across some 3/8" stock, I may switch them out.
Mr.Ron from South Mississippi
Re: Rotary table expansion
Good Morning Mr. Ron.
Thanks for your update on yourRTmodification.
How about some pictures..
Ken.
Ken.
One must remember.
Ken.
Ken.
Here are two views of my RT modified from 6" to 12".
Mr Ron
VERY NICE JOB INDEED
EDIT: I think I will have to make one
like yours, but with one spacer ring all the way
around which should give alittle more support.
Ken.
Ken.
One must remember.
Ken.
Ken.
This kind of extension are found on the net in several places. One variant I used was a solid table with machined buttons that fit the original table T slots so removing the extension can be repeatable within limits.
I didn't use T slots in my extension but just drilled 1/4 inch holes at one inch spacing in concentric circles on the extension plate. I just use hold downs for set ups. I didn't want to use valuable vertical room on my little Clausing mill.
My extension is made from 1" 7075 Al plate.
A one piece spacer ring would restrict tee nut slots outboard of the ring.ken572 wrote:Mr Ron
Ken.
Mr RonMr Ron wrote:A one piece spacer ring would restrict tee nut slots outboard of the ring.ken572 wrote:Mr Ron
around which should give a little more support.
Ken.
You thought I was ignoring restriction comment didn't you..hah.
Nope, you brought up a good point. I think I will go to a 1" or 1.25"
thick spacer ring and cut an abundance of Tee Slots above the original
table, which will fix the outboard problem you mentioned, and also raise
me up a little more, which will be helpful for most of the jobs I will do on
my HF-44142 3in1 Mufti-Machine. It will be an Uninstall/Install Accessory
Plate anyway.
Ken.
One must remember.
Ken.
Ken.
