Hub puller for my new grinder
Changing grinding wheels on one hub is wasteful of the wheel and slow to boot. With my new to me surface grinder I plan on having several wheels of various type and grits mounted/trued and ready to go. But to do that you need a hub puller ,and the grinder did not come with one. Available new for $20 odd bucks but where is the fun in that besides I'm cheap. So off to the lathe and mill and a bit later I now have a puller.
www.chaski.com
Re: Hub puller for my new grinder
John,
Great job and I'll bet it was fun too! Ain't it grand having all the resources to turn a idea into a functional hunk of steel!
Stuart
Stuart
Stuart: Yep sure is nice to have the right tool and even better having the correct tooling to use on said tools. Used my "Top notch" insert holder with a threading insert,boy does it do a nice job of cutting a thread.
www.chaski.com
Looks like you have shown a Sopko adapter and the hub puller you made is nearly identical to the one they market. It is truly helpful when changing wheels.
You did a very nice job on an important tool.
http://www.wmsopko.com/sopko_82.htm
--earlgo
(The original Delta Toolmaker adapter I have does not have any internal threads for a puller and it is somewhat difficult to remove. I need to do something about it, but after 20 years it probably won't happen.)
--earlgo
