earlgo wrote:I bought the 6" 3 jaw because it has removable top jaws and is/was the smallest I could find with that feature. I wanted to be able to use soft jaws because someone suggested it was the best way to go.
I am still having brain cramps believing the spindle is vibrating between the bearings enough (or at all) to cause the chattering.
Perhaps it is time to pry open the wallet and get the bed reground and the carriage mated properly.
Does anyone know if Conrad_R_Hoffman is still around to be queried?
--earlgo
Good Morning earlgo
In addition to finding Conrad,
(Step 1) why not do some
noise and
slop
forensics, so to speak with indicators and stethoscope,
with the spindle gear and the chuck removed from the
spindle while turning
slowly by hand, and or a very
small motor, and
light belt turning the spindle while
watching the indicators and listening to the bearings with
no load on them. (Document all you see and hear)
(Step2) Then repeat after
reinstalling the chuck while it's
snugged up around a small piece of bar stock. (Document all you see and hear)
(Step 3) Now repeat again with the
spindle gear reinstalled.
Note: You will be paying close attention to
rubbing and or
grinding sounds around the
cast area's around the bearings.
Also do a static push test on each end of the spindle at every 45 deg., or so.
(Document all you see)
It might tell you a story on how, and what you need to do to fix it.
Just a thought.
Ken.
