Pretty much the same way, although I do NOT mic the telescoping gauge without going back in the hole, and that is the precise thing that many speak against. Their position in the matter is that you risk changing the reading. My position in the matter is that their thought is true and correct, but it also guarantees that your feel was on center (a proper reading). So then, once the gauge has been dragged past center, it is then reintroduced to the hole, then carefully moved side to side (seeking center) in the bore as it is dragged past center. If one achieves the same feel as was created with the original pass, the gauge measured the centerline. If one does not, the reading would have no value. For small diameter holes, this isn't much of an issue, as the gauge tends to seek center, but larger holes offer far greater chance for error.seal killer wrote:Harold--
How do you use them properly? I saw a video about their use and have followed that method for some time: Stick the gage in the hole at an angle, snug the lock, push the gage past the point where the spindle of the gage is aligned with the axis of the hole and pull it out. Mic it.
I cannot claim to know if that is the correct method. How do you do it?
--Bill
If, after passing the gauge through the bore for a second time, you get the same feel, the gauge should then be measured with a micrometer, seeking center, once again, and achieving the same feel as the gauge passes through the micrometer. This technique will yield measurements that are reliable to .0002" or less.
I speak against the idea of taking several measurements, then taking an average. I'm not too interested in averaging a bunch of wrong measurements.
