That would be obvious, as it's a pale yellow color, and tougher than the hinges of hell.Lew Hartswick wrote:I suspect it's Aluminum-Bronz(e) (Sp?)
Yeah, it's definitely not that...Harold_V wrote:That would be obvious, as it's a pale yellow color, and tougher than the hinges of hell.Lew Hartswick wrote:I suspect it's Aluminum-Bronz(e) (Sp?)
I don't think you want a mirror finish on an oil film bearing, do you? Slightly frosty or matte means there's some tooth for the oil to stick to. Better for the next start-up.ronm wrote:Thanks, Harold. I wasn't super satisfied with the finish, I used Tap Magic Al cutting fluid, & it worked OK, I guess, but not a real mirror finish...anyhow, I suppose good enough for being buried inside an engine.
They did turn out within +- .001 of specs though...
