That's not a good way to operate when you're seeking the best possible condition. Here's why.Falcon67 wrote:>If the chuck has multiple sockets for the wrench, try tightening all of them, as opposed to using just one.
This is SOP - do the same always, including with drill chucks. Never use just one unless I'm drilling cardboard LOL.
The scroll may or may not be dead centered with the theoretical centerline of the thread. It also may not be a snug fit on the boss on which it operates. As a result, one of the sockets will load the scroll in a better location than the other two sockets. For high precision, that's the socket that should be used (exclusively). If you tighten all three, you lose that advantage. This, of course, assumes the scroll is uniform, not distorted in heat treat, in which case, all bets are off.
Explore which socket offers the lowest amount of runout--then mark that socket. Use it exclusively when precision matters, and always when using soft jaws.
