All--
I have a Grizzly 14x14 lathe; G0709. It has a 200 series tool post. What's that mean? Is it an AXA, BXA, CXA or something else?
I THINK I want to upgrade the tool post to either an Aloris or a Dorian. I only think I want to do it because if I am having issues with the stock tool post, I don't recognize them. Would such problems include an increased tendency to chatter? What are the inherent design advantages of the wedge over the piston type tool post?
Thanks!
--Bill
Teach me about tool post sizes
- seal killer
You are what you write.
Re: Teach me about tool post sizes
That would be the equivalent of a BX/BXA. If it's piston, you might well like a wedge, particularly if you've noticed it vibrating loose on heavy interrupted cuts (or chatter), or if you turn in reverse. Other than that, if you've not noticed an issue, I wouldn't worry about it.
Bill : take a look at a Multifix 40 posistion style post . Fairly reasonable from Create Tool out of China. I posted a review of the one I bought back in January. But if you already have a good selection of holders a wedge type post would be a good upgrade.
www.chaski.com
- seal killer
BadDog and John--
Thank you, Gentlemen.
--Bill
--Bill
Seems most people who use the Dorian/Aloris style prefer the wedge. One of the lathes I've run had a CXA Phase II piston on it, and I never had problems with interrupted cuts, i.e. turning square flame cuts, or facing flanges with bolt holes. One problem I did have was Aloris blocks (the tool vendor repped that brand) wouldn't fit. I blueprinted a Dorian post from another lathe and did a little bit of dressing on the face of the dovetail, problem solved. I always blue the base fit of a new post on a lathe...you want as much contact as possible.seal killer wrote:All--
Thanks!
--Bill
Never had the opportunity to try the Multifix, I like the concept. The Aloris style isn't hard to swing around though, just have to indicate for some things like parting.
I remember 1 of the lathes @ work had the Multifix tool post. Not sure if our 2nd lathe had it. It was what we had so I really can't say how it compared to the wedge or piston type tool posts.
The lathes were probably twice the size of my 12 x 36 lathe so the rigidity of the lathe & its accessories was probably similar.
