Clausing 5900 lathe, whats your take?
Re: Clausing 5900 lathe, whats your take?
L tapers work excellent and have large pass through. Wrenches are easy to make or buy... and yes you need a wrench.. not good for spindle nose, chuck, or work to run loose.
This guy cuts them out of plate:softtail wrote:Wrenches are easy to make or buy... and yes you need a wrench..
http://www.practicalmachinist.com/vb/to ... -00+wrench
- Location: The Warm Arizona Deserts... Phoenix to be precise...
Yes he does .... and I own one...SteveM wrote:This guy cuts them out of plate:softtail wrote:Wrenches are easy to make or buy... and yes you need a wrench..
But my Clausing 59XX and the spare headstock I have does not use a standard L00 wrench. The wrench I bought from him fits my Le Blonde dual drive like a glove...
I think the wrench I use is a Proto 1/2" pin 3-3/4 pin wrench.
One like this:Lazz wrote:I think the wrench I use is a Proto 1/2" pin 3-3/4 pin wrench.
