Can't hold tolerance with finish cuts
liveaboard
Re: Can't hold tolerance with finish cuts
Post by liveaboard »
I also replaced my crossfeed screw and nut recently.
Very satisfying.
I used an off-the-shelf screw and nut, cut and pressed the new screw onto the old spindle. Cheapo solution for a lathe with zero parts availability.
