Geometric Thread Chasers
JohnHudak
Post by JohnHudak »
Hi All, I recently picked up a Geometric 5/16 DSA thread chaser head.. I was wondering which series chasers will fit it? Will D or DS inserts fit my DSA head?
Thanks; John
Russ Hanscom
Re: Geometric Thread Chasers
Post by Russ Hanscom »
Go to the Geometric site or similar and there will be a table of what chasers fit what head. In some cases, the D and DS chasers will not work in the same heads.
Geometric used to be a part of Greenfield Tap & Die - not there now, just checked - will have to search.
Post by GlennW »
From the Geometric Manual:
While I'm at it...
OK, one more.
Russ Hanscom
Russ Hanscom
What I just found: Geometric® brand was acquired by ATI Stellram's Landis® Threading Systems in June 2013, & later sold to Landis Solutions, LLC.
Still having trouble finding anything of use there.
JohnHudak
Post by JohnHudak »
Wow, great info there... Thanks to everyone..!
Glenn, from your first photo, it looks like style "D" chasers will fit all of the D heads, D, DS, DSA
I guess I'll order a set and try it out..
Thanks again
Russ Hanscom
Better order chasers specific to your head model - if a D, DS probably will not fit. I have several geometric heads and chasers are generally not interchangeable between different models. The chasers all look alike but some critical dimensions are not.
There is a chart out there somewhere that shows what will fit where - used to be on the Greenfield site - no longer.
