holding workpiece against spindle center
TRX
Post by TRX »
Let's say I have a long workpiece that has to be supported on a steady rest since I'll be working on the tailstock end. If I want to use a center and drive dog at the headstock end instead of a chuck... how do I keep the workpiece pulled up against the center?
My old "How to Run a Lathe" book suggests soaking strips of leather in water, tying the dog to the faceplate, and waiting for the leather to dry and shrink.
Besides losing ground in The Eternal Battle Against Rust, threading strips through the holes in the faceplate and around the workpiece and tying them in some way that doesn't try to pull the workpiece to the side as they dry looks like a hassle. And the only "leather strips" I've ever encountered are leather boot laces, and those didn't shrink when they got wet. Maybe they're treated somehow.
Try boot laces anyway? Find "leather strips" on eBay? Is there a better way?
whateg0
Re: holding workpiece against spindle center
Post by whateg0 »
make up a set of parallel bars like a real basic tap wrench, but with holes in the ends to run bolts through to the faceplate.
TRX
Post by TRX »
I thought of something like that using springs, but I was wondering if there was a better way.
whateg0
Post by whateg0 »
I wouldn't tighten them down until the steady is running true. In fact, if you used a couple of them at 90 degrees to each other, you could use that to get the work running true and then just bring the steady into the work. YMMV
I'm curious why you don't simply hold the material in a chuck, or even a collet. No amount of lashing will create a robust setup, so even if you had success (to some degree) you'd still be limited. That wouldn't be true of a collet or chuck setup.
earlgo
Post by earlgo »
At the CST in the '70's this is the way we held rifle barrels against the center for chambering.
Unscrew the faceplate a couple of turns.
Clamp a lathe dog on the part to be turned.
Lace a length of nylon rope around and through, etc. making sure the knots are tight and the ends are not floppy and that the dog and part is pulled securely back against the headstock center.
Tighten the faceplate so that it really tightens up the rope lacing.
Adjust the steady rest so the center of the bar is aimed at the tailstock center. This is not an easy thing to do with any accuracy.
This will get it done so that the chamber or whatever is in the center of the bar. (If the OD is not concentric with the bore, then there are other problems that need to be fixed.)
Hope this inspires you for your own solution.
--earlgo
TRX
Post by TRX »
Harold_V wrote:I'm curious why you don't simply hold the material in a chuck, or even a collet.
I had a tapered or non-round part in mind.
earlgo wrote:Unscrew the faceplate a couple of turns.
That sounds like the trick!
Re:
That helps me understand, but proceed with caution. The slightest misalignment of the part in relationship with true center will cause the part to walk in a steady.
I expect that even tapered or not round objects can be held adequately with a four jaw. That's assuming you aren't relying on a center at the chuck end to determine the proper attitude of the part. If it must be true to the center, then lashing is likely an acceptable solution. Just be careful! :-)
SilveradoHauler
Post by SilveradoHauler »
Easy as pie. Think "4 jaw chuck".
Re: Re:
Post by John Hasler »
Harold_V wrote: Tue Jul 25, 2017 4:00 am
Use the four jaw. Drill and tap that hole where you were going to put the center. Run a threaded rod through the spindle bore and into that tapped hole. Use a nut and washers to draw the rod tight like it was a collet drawbar. I've used similar setups where I was afraid that the part might walk out of the chuck.
