Odd Size Drive Plate
angelo49
Post by angelo49 »
I have this 5'' drive plate with a 7/8'' x 9 tpi thread.
the ID is .766'' which makes the 7/8'' OD correct. (adding one pitch, .111'' to the ID)
I might have posted about this a few years ago but I'm not sure.
I can't find any machine with this thread.
Any ideas ??
Angelo
Re: Odd Size Drive Plate
Post by spro »
I guess somebody needs to ask if this is metric. 9 TPI is weird.
angelo49
Post by angelo49 »
That's what I thought, but it's not that uncommon.
It's definately not metric.
http://www.victornet.com/reference/Tap_Drill.html
Angelo
Post by spro »
I measured a collar of 1 3/8 X 8. There were only three internal threads but the gages know the difference between 8 and 9. You know what you are doing. Some one here knows that spindle.
Mr Ron
Post by Mr Ron »
Could it possibly be for a wood lathe?
Mr.Ron from South Mississippi
Post by spro »
Respectfully, why would that be?
angelo49
Post by angelo49 »
Mr Ron wrote:Could it possibly be for a wood lathe?
I googled every which way possible and the only place I found that thread
was for taps or dies.
No machine spindle.
Angelo
Post by John Hasler »
Shop made for some special purpose?
