Hello All New here.
dash9
Hello All New here.
Post by dash9 »
Hello to all the metal workers, I am new on here and not so new to metal working. Not good at it thou. Had a Bridgeport mill
i got 50 years ago. Was young and really dumb, wanted to cut a plate and just could not figure on how to hold it down and being in a hurry I thought I could hold it and mill it. WRONG... well after 55 stitches and two surgeries I wont do that again.
Re: Hello All New here.
Post by spro »
Hey dash9 ! Welcome to the Board! I'm very sorry for that serious injury but you will find that other things have/can happen with equal or worse consequences.
Anyway, glad you are here. You could probably spend a month just reading earlier posts. The search engine works fine for specific areas of interest.
Folks do like real time answers and fortunately, members still post them.
Post by SteveHGraham »
I regret using a 3/8" carbide end mill to clean my ears.
Welcome to the forum.
earlgo
Post by earlgo »
Indeed welcome, Dash9.
At one point, I thought I could hold a piece of brass plate while drilling a hole in it. Not a good idea, but didn't end up as badly as your experience.
Steve: Hopefully the mill wasn't running... :roll:
--earlgo
SteveHGraham wrote:I regret using a 3/8" carbide end mill to clean my ears.
Anyone with the least bit of understanding should know that ears are best cleaned with a 1" HSS aluminum cutting end mill.
Mr Ron
Post by Mr Ron »
I think a unibit would work better.
Mr.Ron from South Mississippi
Post by spro »
This getting funny. I knew this older guy who was a serious crafts man and carpenter. During a conversation would whip out his truck keys and ream out his ears. I hadn't seen that before. When the truck started, it became eerie.
Like I said, he was serious but keen sense of humor. :)
Harold can never resist showing off.
neanderman
Post by neanderman »
Who here hasn't, at least once, tried drilling a hole, freehand, in a sheet of something, only to have the bit 'grab', turning that previously innocuous bit of metal into a spinning, finger hungry, virtual knife blade?
Who, me? Nah...
Postscript: I do still have all my digits (knock wood...)
Ed
LeBlond Dual Drive, 15x30
US-Burke Millrite MVI
Atlas 618
Files, snips and cold chisels
Heh! Steve's comment about me showing off. If that was my intent, I'd have suggested a 1½" rougher end mill. It is my opinion that, for Steve, the 1" end mill would be a good fit. :P
Holding things by hand to drill holes. Done it most of my life, and, for the most part, I have escaped without issue. However, I can certainly recall the time I was doing a home job (working at Sperry) having to open up a pre-drilled hole in a brass base plate for a model engine I was building.
Need I say more?
I will comment that I escaped serious injury, but drilling in brass without holding the item securely is a huge mistake!
Lately I've had good results with the blowgun.
Post by NP317 »
Dash9:
Welcome. (again)
You've now met some of this Board's Main Characters.
You get the idea.
But they DO offer some of the best advice available, despite the ear-cleaning stuff.
Jump in and enjoy the Folks and Knowledge here. Priceless!
