Taper attachment info for DL 1860
Moderators: Harold_V, GlennW
Andy Rafferty
Post by Andy Rafferty » Tue May 15, 2018 7:33 pm
I recently took over a machine shop. Shortly before my arrival a lathe marked Birmingham with the above model # was set up. The boxed taper attachment found behind it is for a 22 inch Enco. I need a taper attachment. The lathe cross screw doesn't extend beyond the slide like a SB so I expect to have to build the extension from the nut to the taper attachment but I would cherish any and all input. Thanks for your time. Andy
Glenn Brooks
Re: Taper attachment info for DL 1860
Post by Glenn Brooks » Wed May 16, 2018 12:55 am
Andy, Iam not familiar with the machine you identify. Also not clear if you need a new taper attachment, or does the Enco one fit, but just needs a longer screw?
If a longer screw, you could have someone make a new screw (and nut , if needed ) to tie everything together. Might also have the benefit of improving your surface finish and precision re: DOC with a new, unworn cross feed screw and nut. It certainly did on my SB Fourteen.
Cheers,
Andy Rafferty
Post by Andy Rafferty » Wed May 16, 2018 4:33 am
Thanks Glenn, I hope to find a taper attachment to fit, the Enco part won't bolt up but could be adapted as with the steps you described. Thanks for your help.
