Monarch lathe
Mr Ron
Monarch lathe
Post by Mr Ron »
I was watching a video featuring the Monarch model 10EE lathe and noticed that the X and Y axis can both be powered at the same time. What application would use this feature?
Mr.Ron from South Mississippi
Re: Monarch lathe
Post by John Hasler »
Cutting a taper.
Re: Monarch lathe
Post by BadDog »
A very specific and not terribly useful taper since you don't have any control, much less fine control, of the feeds independently. Unless there is something I'm missing, I would expect it's just a peculiarity of the design that didn't require independent lock-out rather than actually a feature.
Re: Monarch lathe
Post by SteveHGraham »
Monarch makes (made?) taper attachments.
Re: Monarch lathe
Post by BadDog »
I expect they are still made, or can be had made, but only lawyers (and their cousins the politicians) can afford them.
Re: Monarch lathe
What about rappers?
Re: Monarch lathe
Post by BadDog »
Yeah, ok, but they wouldn't know what to order, and it doesn't come in gold plate.
Re: Monarch lathe
BadDog wrote: Tue Jul 10, 2018 5:14 pm A very specific and not terribly useful taper since you don't have any control, much less fine control, of the feeds independently. Unless there is something I'm missing, I would expect it's just a peculiarity of the design that didn't require independent lock-out rather than actually a feature.
But it is the ratio of the feeds that controls the taper, since everything is gear-driven and therefor synchonous.
However, it turns out that you can't engage the leadscrew and the power crossfeed at once: just the power feeds. There may not be many options after all.
Re: Monarch lathe
Post by BadDog »
Exactly my point. The taper is defined by the ratio of the long feed vs the cross feed with no way to change the ratio. If that happens to be 2:1, then you can turn 2:1 (half angle) tapers, perhaps with the compound for depth of cut, but it's not much use otherwise. Maybe that might produce things convenient for an aesthetic feature, but not likely anything else.
Re: Monarch lathe
Correct. If it generated a 45° angle, it would be quite useful, but it doesn't. It can be used to break edges when the angle isn't critical, however. That was something I did on occasion when I was assigned to an EE. Problem was, pretty much everything was specified (including edge breaks), so I wasn't at liberty to use it much.
whateg0
Re: Monarch lathe
Post by whateg0 »
I don't think it cuts a 45 on mine. Maybe it does. It is certainly not a substitute for the taper attachment. I agree with BadDog that it's not necessarily a "feature", but something that didn't need to be made another way.
Dave
earlgo
Re: Monarch lathe
Post by earlgo »
The ATLAS 12" lathe will also engage both lead-screw and cross-feeds at the same time, but I have never tried it. Might be fun to see the flinders fly. :shock:
--earlgo
