Change lead screw to metric?
Moderators: Harold_V, GlennW
tornitore45
Re: Change lead screw to metric?
Post by tornitore45 » Sun Jan 26, 2020 5:39 pm
I tried a couple of examples an found you can make some limited metric and imperial pitches but not many.
The change gear set you have seems to have several duplicated prime factors but not enough range to cover all standard.
Teeth Prime Factors
25, 5 5
30, 2 3 5
38, 2 19
40, 2 2 2 5
42, 2 3 7
50, 2 5 5
55, 5 11
60, 2 2 3 5
60, 2 2 3 5
70, 2 5 7
80, 2 2 2 2 5
84, 2 2 3 7
89, 89
100. 2 2 5 5
For example there is no way to make a 10:1 ratio in two stages but is possible in 3 stages. 100/25 50/40 and 60/30
A commonly needed ratio is 1:5 but is not possible in one stage. Two stages requires 1.25 x 4 obtainable with 100/25 and 50/40
Your limited Max and Min No of teeth limits the max ratio you can get in one stage
A 75 teeth and another 25 may be helpful to make 1:3 and 1:4 ratios
30/89 is close enough to 1:3
Metric to metric requires ratios of 2 and 5 7 and 3. You can do 7 and 3 but 5 requires 2 stages
To make a long story short you need to expand the range of gear you need to mount on the banjo.
Making a shaft reduction adapter may let you use gear smaller than 25 teeth and the picture seems to imply a larger than 100 teeth is possible if meshing with a smaller gear.
Just for fun, tell which pitch you could not accommodate and see what is needed for those.
Mauro Gaetano
in Austin TX
liveaboard
Post by liveaboard » Mon Jan 27, 2020 2:24 pm
Thanks for that; helps clarify.
It looks like a lot of my trouble is the need to reduce the feed...
a 4mm screw might make that easier.
Smaller than 25 would require a lot of effort; bigger than 100 might work sometimes but the cover might not close.
I'm going to put it on the back burner for now, until I go to Lisbon next [could be a while].
I'll be working on my shopping list though.
liveaboard
Post by liveaboard » Mon Jan 27, 2020 4:26 pm
I was trying to do math and my brain was getting more and more kaleidoscopic...
I found a great program for gear calculations.
http://varmintal.com/alath.htm
and download gear vb61 zip file.
You can put in any leadscrew [inch or metric], your own gear set, and ask it to calculate the gears for any thread, inch or metric.
It's not clever enough to know if the selected gears will actually fit together; but it gives you several possible combinations.
So my existing gear set can apparently make just about any thread, with a 4 or a 5mm screw.
whateg0
Post by whateg0 » Mon Jan 27, 2020 5:00 pm
Not sure about the remaining calculations, but you need to omit the transposer gear for metric. That is such a strange setup. Why did they choose to use an imperial screw? There surely were metric screws available at that time. Strange!
Dave
liveaboard
Post by liveaboard » Mon Jan 27, 2020 5:12 pm
The lathe was sold in imperial and metric versions.
For metric, only the top + cross slide screws + dials were changed.
It seems to be quite rare. I once saw one [inches] on ebay UK, and I found a blog with pictures of one in Poland that looks like it was never used, and it has the inch dials.
Since they never used inches in Poland, and this is Polish made, I guess it's a leftover or from the factory museum or something.
But why they chose what they chose? Who knows?
Mine seems to have a 3-phase 180V motor rewound to 380V.
No one has ever heard of 3-phase 180V.
f350ca
Post by f350ca » Mon Jan 27, 2020 5:45 pm
I have a 16 x 80 lathe imported from Poland by Summit Machine Tools. It has inch pitch lead screws that are metric diameter and trapezoidal metric thread form.
Greg
liveaboard
Post by liveaboard » Mon Jan 27, 2020 6:40 pm
I never actually measured the diameter of the leadscrew closely enough to know whether it's 25mm or 1"; but now I will.
I don't know how to tell the difference in the thread form.
My lathe was built sometime during the crusades.
f350ca
Post by f350ca » Tue Jan 28, 2020 11:13 am
I had to make a new lead screw for the compound after a crash. I ground an 29 degree acme cutter, when I check the fit on the bent screw it didn't match. Hum. Did some research and found there was a 30 degree metric version of acme. Ground that and it matched. The new screw fit the nuts perfect.
Greg
Magicniner
Post by Magicniner » Sun Feb 02, 2020 12:54 pm
NthreadP is a calculator which takes your driving gear size. lead screw pitch, your available change gear sizes and calculates the gear possible trains for the thread of your choice.
http://www.lathes.co.uk/latheparts/page14.html
I use it to cut metric and imperial threads on my change gear Myford Super 7 with imperial 8tpi lead screw
tornitore45
Post by tornitore45 » Sun Feb 02, 2020 2:09 pm
Calculating the gear train is the easy part. Coming up with a solution that physically fits on the banjo is the hard part.
Mauro Gaetano
in Austin TX
Magicniner
Post by Magicniner » Tue Feb 04, 2020 9:55 pm
Ah, but nThreadsP gives you lots of options, it gives you all the possible options with your set of gears, it even allows you to choose to allow an acceptable error if you so wish.
tornitore45
Post by tornitore45 » Wed Feb 05, 2020 7:29 am
The thing I hate the most about changing gear is getting all dirty, jiggling the gears to slip over the shaft key and handling all the fiddly parts involved.
I have coded the constraints about the 4 gears involved into four conditions my spreadsheet analyze and report if anyone is not met.
When I get down in the shop I already know which solution fits.
Did I mention I love spreadsheets?
Mauro Gaetano
in Austin TX
