muddstopper wrote:
I think Harold may have unknowingly found what has caused the problem in the first place.
Heh! Not exactly unknowingly. You see a lot when you've been around machines as long as I have. You can trust me on this one----you're not the first guy to have something come out of a chuck. (Don't ask!)
Quote:
Now how do i fix it?
This is where a careful inspection is the word of the day.
Take the jaws out and look at the slide area in the chuck body. Compare one to the other, paying particular attention to the one you suspect is damaged. It's highly unlikely the jaws will have any damage, they're generally well heat treated and have considerably greater tensile strength than does the body.
Look for irregularities in the slide area---a step, maybe a fractured area----what ever. If the body is steel, it's unlikely to be fractured, but it could be deformed. If that be the case, depending on how the chuck is built, you may just have to live with it. You may envision a way to press the slide back straight, using a heat treated well fitting object and pressing in a large press, several tons capacity. It's a long shot, all depends on what you find, if anything.
Quote:
The jaws are two piece.
That may change, to a minor degree, how you go about grinding the jaws, assuming you do. If your chuck is built such that the top jaw makes contact with the material, but the portion that runs in the slide doesn't, all you have to do is place your spacer (the disc you'd use for grinding) in that area, then grind only the top portions until they all clean up. The same rules set forth earlier still apply, only the "kill the small area" would change, for it may not touch, and won't matter. Make sense?
That you have two piece jaws is really a good thing. If you get interested in using soft jaws, you're already there. If you're not familiar with soft jaws, and want to be, there's a long post I made a few years ago that addresses them well, and should provide all the guidance necessary for you to have a firm understanding on how to make them, and how to apply them. I could provide a link for the post if you're interested. The pictures that went with it won't be available any longer, but I could repost them if necessary. The new software wasn't compatible in that regard, so pictures, for the most part, have all been lost.
Quote:
Another question, just in case I run across another chuck how do I determine if it will fit my lathe.
Bill has addressed that nicely. The only thing I'd add is that you should keep in mind the size of the hole in your spindle, and make sure any chuck you acquire has a hole in the chuck body no smaller than the spindle bore. Only is you mount an unusually small chuck would that be a consideration, however. If your lathe is an early Monarch, that's probably not much of an issue, but later machines can have larger spindle bores, and it would be a shame to lose the capacity, especially if you're inclined to run fairly large diameter pieces.
One more thing. Assuming the slide is damaged, and the damage is general in nature (not a sharp ridge, for example), the grinding operation we've talked about will improve the chuck drastically, even if you don't make any corrections on the slide.
If you do find it is sprung, only one slide, select the average of the sizes you intend (or expect) to machine, and set the jaws for the average. That way the amount of error you get from the jaw will be split evenly from top to bottom size, with a perfect (?? You know what I mean) fit in the middle. In the end, you'll be quite surprised how well the chuck runs as compared to how it is now.
If you're real lucky, and the damage is well spread between all three slides, which I really think it is (sprung chucks are not uncommon), the chuck will run beautifully when you're finished.
Don't get discouraged with this thing yet----
Quote:
In case you cant tell from my post, I own a lathe, I aint a machinist.
None of us were born with machining knowledge. It happens I've spent more time in the environment than you have-----that's the difference. Otherwise we each put our pants on one leg at a time. What really matters is your attitude----and yours is healthy. Not everyone welcomes input as you do, and that's an ongoing problem for people like me that run their mouths overtime----it's not always welcome.
Thanks for putting up with me.
