The Home Machinist!
A site dedicated to enthusiasts of all skill levels and disciplines of the metalworking hobby.
It is currently Fri Sep 10, 2010 6:59 pm
Post new topic Reply to topic  [ 89 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
Author Message
 Post subject:
PostPosted: Wed Jun 21, 2006 1:45 pm
Offline
ZipSnipe wrote:
Thanx Harold, your the man, out of all the machining forums and guys who post stuff on 'em your posts have always been the intelligent and made sense to me the most.
Heh! It's just that I have a great ability to BS people! :lol:
Thanks for your kind words, though. It's nice to realize I actually help on occasion. I was fortunate to have some terrific mentors. It's now time to pass along the good things they taught me.
Quote:
So its normal for a chuck to run about .002 out?
Yeah! Absolutely! They're made by people, all of whom have good and bad days. Further, the design, while certainly not bad, isn't perfect, either. Couple that with heat treat (distortion) and human screw-ups (crashes of various magnitudes), even a chuck that starts life perfect soon has some error. What you do is learn to work with it. It's like backlash. A fact of life.
Soft jaws seem to be a stumbling block for some folks----thinking they're a production tool, and not really necessary. That's just not true.
Because universal chucks have error, and because holding some pieces can be challenging under the best of conditions, soft jaws are often used for a one-off. They solve almost every problem you can imagine where chucking is concerned. Especially if you have an imagination and have irregular parts to hold and index. Soft jaws can be milled to hold almost anything.
Not pushing you towards soft jaws, understand. Just trying to help you understand the significance----and to not beat yourself up because you have a Chinese machine. Any machine, even a rusty one, beats no machine.
Top
 Profile
 Post subject:
PostPosted: Wed Jun 21, 2006 7:02 pm
Offline
I don,t even know what a soft jaw looks like. Much less what it does. I will tell ya I probably spent at least an extra two hours trueing up my workpiece( pulley) just to make sure i get it perfectly round or within .002 ....
Top
 Profile
 Post subject:
PostPosted: Thu Jun 22, 2006 12:01 am
Offline
Quote:
ZipSnipe....... I don,t even know what a soft jaw looks like. Much less what it does. ....
I don't think I know that much about them. How about a little information like can you use them on a regular chuck or does it take a special chuck?
_________________
Keith, From the land of Oz, although not the Wizard of.
Top
 Profile
 Post subject:
PostPosted: Thu Jun 22, 2006 12:38 am
Offline
Here's a link to a post about soft jaws.
http://www.chaski.org/homemachinist/vie ... php?t=4266
There were several others that commented, so the thread is a good place to start learning about soft jaws, and how useful they can be. There should be enough information in that thread to get anyone up and running.
Not sure any of the pictures will show now, but if anyone is interested, I can post pictures of soft jaws and the spider of which I spoke in the post. The spider is used in machining the soft jaws. The greatest advantage in using it is that you can re-install the soft jaws and take a truing cut that removes only a few thou from the jaws. That way, soft jaws can have a long and useful life. All of this will make sense when you understand how soft jaws work, and how they're machined.
Soft jaws are usually bolted on the top of master jaws, in place of the hard top half. Chucks that have two piece jaws, in other words. Not having the two piece jaws does not eliminate one from using soft jaws, however. Recently a fellow in California made some soft jaws that went on his hard jaws that worked very well. If you're interested in exploring his method, look here:
http://www.homeshopmachinist.net/bbs/sh ... =soft+jaws
Assuming you'd have an interest in duplicating his method, I strongly suggest that jaws be made that fit over the hard jaw and are bolted securely. That insures the jaws are reliable as stops, and won't move to destroy their considerable precision. I'm open to discussion if anyone is interested.
Top
 Profile
 Post subject: Soft Jaws
PostPosted: Thu Jun 22, 2006 4:59 am
Offline
Hi Harold
Thanks for the link to the thread about the soft jaws. The pictures didn't show and I am interested in learning more about this. If you can post the photos of the jaws and the "spider" I may be able to better understand all of the text information.
Since I trued the jaws in my 6"-3 jaw chuck it has been a pleasure to use.
Ernie F.
Top
 Profile
 Post subject:
PostPosted: Thu Jun 22, 2006 1:20 pm
Thanx harold , I too don,t have a clue about what the spider is. The soft jaws from what I gather sounds like an extension of the harder jaws only the extension is made of a softer material and is bored to the same dimension of the part that your tryin to turn, am I right?
Top
 Post subject:
PostPosted: Thu Jun 22, 2006 2:10 pm
Offline
Typically, soft jaws replace the top half of two piece jaws. Small chucks, particularly those made for home shop machines, don't often have the two piece jaws, so in that case a soft jaw must be fashioned that fits over hard jaws. It's not the best scenario, but it beats not having soft jaws. Yes, you are correct. Soft jaws get profiled to match the part you intend to hold---and the fit must be close, so you use the same portion of the scroll. If you machine the fit sloppy, the soft jaws will usually have runout.
I'll post some pictures this evening---soft jaws and the spider----which will help some of these things make sense. I'm out of time at the moment.
Top
 Profile
 Post subject:
PostPosted: Thu Jun 22, 2006 2:58 pm
Kool thanx again Harold. Once again you reign supreme in the area of knowledge and helpfulness !!!!
Top
 Post subject:
PostPosted: Thu Jun 22, 2006 6:36 pm
Offline
Wierd it said I,m a guess, umm?
Top
 Profile
 Post subject:
PostPosted: Fri Jun 23, 2006 3:10 am
Offline
First pic is a set of aluminum soft jaws. They have been used but once. The gripping surface is the small radius cavity you see in the picture. Jaw blanks are typically made rectangular, without the step, but the material I had on hand already had that configuration.
Notice that the jaws are somewhat symmetrical. If you make your jaws wisely, you'll be able to reverse them, using both ends for different configurations. Also, making them from steel instead of aluminum allows for welding pieces back on when you've used them up. I've done that with several sets in the past. That way you avoid making new blanks. While aluminum can be welded, it also softens the material, which is not desirable. I look at aluminum soft jaws as disposable when they're been well used, but have never discarded a steel set.
Second pic shows my 3 jaw with one of the jaws removed. It's an unusual chuck in that it has a key to register top jaws on the master jaw. American-made chucks tend to not have the key, but rely instead on a boss. It's somewhat more difficult to make the blanks with the boss than the key because of corner radius interference, but it's possible. A small end mill and an undercut works well.
Note that the slot width locates the jaws sideways. The slot and key (or boss) should always be a snug fit to prevent jaw movement under load, and also to assist in proper register when re-installing the soft jaws for future use. That helps minimize the amount of material that must be removed for a new configuration.
If you'll study the second pic, you'll notice that the cavity has two different configurations bored within. No need to completely remove the old one, just establish a generous gripping surface (and, in this case, a shoulder on which your part will locate). Because you have such large area of contact, and it conforms to the diameter of your part, the parts don't get marred, and they also tend to stay round when you grip thin walled objects.
Third pic is the spider. Nothing more than a hex nut that is drilled and tapped for, in this case, 5/16"-18 SHCS of various lengths. I've discussed the spider and reasons for its design in the earlier referenced thread, but if you don't find an answer to any questions there, feel free to inquire further.
Top
 Profile
PostPosted: Fri Jun 23, 2006 7:09 am
Offline
Hi Harold
Thank you for posting the photos. I understood the spider from your text description. The photos cleared up my understanding of the soft jaws very nicely and I can see the many benefits of using them. I imagine the uses could be endless. I have machined myself into a corner so to speak and couldn't remove the part without losing accuracy on my one piece three jaw chuck. :oops:
Ernie F.
Top
 Profile
 Post subject:
PostPosted: Fri Jun 23, 2006 1:57 pm
Offline
Now let me see if I got this right, the spider will be held in the jaws of the chuck at the furthest outside edge and then you are to bore upto the spider? And is this boring operation taking place on the lathe or mill? Also what about making softjaws for one piece jaws that is lets say C-shaped and it kinda wraps around the jaw with maybe set screws on the side? Think that could work?
Top
 Profile
 Post subject:
PostPosted: Sat Jun 24, 2006 12:16 am
Offline
In a sense, what you said is correct, but there may or may not be an edge to which you will set the spider. I've set the spider on the master jaw, or on the soft jaw portion, depending on what I'm doing. The purpose of the spider is to load the jaws as they would be loaded holding a part you intend to machine. In order for the spider to compensate for the wear and springing most 3 jaw chucks have, the spider should be placed as far out as possible, but still allow for the jaws to be machined where the part will fit. As you get nearer and nearer the scroll, the less effective the spider becomes in tilting the jaws (less leverage), which is really what's happening, along with loading them against the scroll.
Depends. If you're turning a piece that is round, you want to do the machining with the chuck on the spindle, and not remove it for any reason until the job is finished. You bore the jaws the same way you'd bore a part. While you should be able to remove and replace a chuck, there's no guarantee that they will seat exactly the same way each time, so boring on a mill should be reserved for those occasions where the lathe won't do.
Assuming you want to chuck an irregular shaped object, using a vertical mill, you'd dial in the chuck body (looking for theoretical center) and from that machine the jaws according to the configuration at hand. It can be trying if you're not a seasoned mill hand, but with care you can establish a very well located cavity that will run each part identically, assuming they are all the same size.
Using soft jaws is something that will teach you to start holding diameters close, even when they don't have to be for other reasons. If you don't hold the parts identical to one another (± .001"), you shouldn't expect the soft jaws to run well. The extra time spent holding diameters close will be more than repaid when you second operation the parts. The more you have to handle the parts in question, the more soft jaws are to advantage.
I would advise against that design, although it would work. What you want is something that clamps the jaw closed on the hard jaw. You'd do the same thing you're talking about, but you'd make the jaw deep enough to permit drilling a cross hole on top of the jaw, where you'd install a bolt that, when tightened, clamps the sides of the soft jaw against the hard jaw instead of spreading it.
It's important to make your jaws such that they can't be moved about once installed. If they are free to move, you're highly unlikely to be happy with the results. If you make jaws that can be moved, they'll work, no doubt, but the precision that is usually expected will be hard to come by.
Top
 Profile
 Post subject: Re: Soft Jaws
PostPosted: Sat Jun 24, 2006 12:29 am
Offline
Metalman wrote:
Hi Harold
My pleasure! Really! :D
I hope to get lots of people using soft jaws. If I'm not remembered for anything else, I will be remembered for that.
There's no good reason why the home shop shouldn't be enjoying some of the methods that the commercial shops use---particularly when it's so easy and beneficial. They really are that magic bullet you need in the shop-----and can be added without spending any money in some cases.
Ernie F.
Your example is a good reason to use them, but they're more than that. Even when high precision isn't a requirement, because you can use them as stops, locating each part perpendicular, and they will run so nicely, even when you screw up and don't hold diameters closely, they save so much setup time that they are worth their weight just for that. When you have multiple parts to run and must handle them through several operations, they're impossible to beat. And then there's that strange part that you have a hard time setting up-----a thin object, for example. You can face off 1/16" thick "washers" or plates and hold them parallel within a few tenths, no big deal. Their uses are endless-----and limited only by one's skill and imagination.
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: tarzan and 4 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
Localized by Maël Soucaze © 2010 phpBB.fr
