BigBob wrote:How do you attach photo... I have on hard disk.
If you'd like to have the Chaski board host your picture, all you need do is click the Browse button, found below the box in which you compose your post. The blue line above the Browse button says Upload Attachment, assuming you are using subsilver as your board choice.
When you click the Browse button, the software will then allow you to go to your stored pictures. Click on the one you choose to post, than click Add the file. Done. You can add more pictures by clicking the Browse button once again. Take note that you can assign the pictures to display in the order of your choosing, or you can even place them within text.
If you prefer that pictures be hosted off the Chaski site, please insure that they display no larger than 800 pixels in width, to avoid spreading text off the screen. Size is not a consideration if you post only the link, so pictures do not run automatically.
