Hi,
A long while ago, on the old board, someone was advertising a lathe RPM/SFM display/calculator. As I recall, the setup was very resonable in price, something under $100.
Anyone recall the name of the company selling this item?
thanks,
mark
lathe RPM/SFM display source?
Re: lathe RPM/SFM display source?
Yep. I bought a tachometer kit from Dan Mauch at Camtronics. I'll see if I can find his web site hereabouts.
If not, check with the guys over on the CNC section as he's a pretty popular supplier over there.
I found it -- http://www.seanet.com/~dmauch/
For some reason I can't get this thing to treat the above as an URL. I'm afraind you'll have to cut and paste.
== Cliff
== Cliff
Cliff, How do you like the tachometer kit? Is it very hard to put together? I am interested in 0-3000 rpm.
Thanks.
Greg
Thanks.
Greg
Greg,
Well, I've had some experience in assembling kits. It's a pretty basic kit, the PC Board with masking to show component location, a simple set of instructions, and the parts all together in a zip-loc bag.
That said, I like it. But it's nowhere near like the old Heathkits (which came with huge manuals and ANYBODY who could read could assemble).
Its a great value and perfect for the somewhat electronic-minded.
== Cliff
== Cliff
Cliff,
Dan Mauch from Camtronics sent me the assembly instructions. I think I will give this project a try. It is definite at the right price. Anything else I have found costs a lot more. Did you check the accuracy of the tachometer against something else after you installed it? How close was it?
Thanks.
Greg
Thanks.
Greg
No, I didn't check the accuracy. But any problems woul be with the sensor; keep things clean and contrast high and you shouldn't have any problems.
not sure what you were doing -
all you have to do is type your URL as "www.google.com "
without the quote marks - www.google.com
and this forum does it for you -
Dave
Smithy 3in1, Select Mill, Atlas 6" lathe
Yeah, I just expected it to show up as such when typing it in like a word processor, I guess. It ended up just fine.
Oh well. . . . .
Oh well. . . . .
Re: lathe RPM/SFM display source/accuracy
I inquired of the kit also and asked him of the accuracy. He claimed +/- 15 rpm.
