EMCO Compact 5 CNC lathe
Re: EMCO Compact 5 CNC lathe
Why not put your own Step and Direction controllers on it, like geckos, and run Mach or VMC? Your 99% there already.
James i was pulling my hair out with the same problem for a week. The yahoo compact 5 Group had a thread about the capacitors going bad on the circuit. I took it to an electronics guy who supposedly checked the caps as ok. I decided to change them out anyways and $3.50 latter in parts and with a bit of adjustment in the pot, wah lah up and running. Let me know if uo have a problem identifing which ones and i can send a pic when i get home.
The caps on my Maximat V10-P where giving me trouble.
The machine has a double speed per every gear change, the second faster speed is done by the capacitor making the motor go to double speed of sorts.
I change the capacitor and it worked fie for a while, but a the top speed it still bog-down.
What I did is to add the older cap in parallel and now it works as expected.
