My position on that subject is much the same as learning to play a musical instrument. There's no shortcuts---you must learn the scales, and practice. The point being that unless you understand cutter geometry, you can't evaluate problems when they arise, as they have in your case. By grinding HSS tools, you gain the required understanding---which then allows you to solve problems without being at the mercy of suppliers of carbide tooling. If you expect to perform at a specific level, you must jump through the hoops required.jpad wrote:@Harold,
Can you please give a little more info on the mistake of using inserts vs. grinding my own tools. Yes, my thinking was use inserts to save the learning curve of grinding my own. My thoughts were just stick the insert in and go, looks like I might have been mistaken.
Few with small machines benefit from insert tooling. It's costly, and often can't be used to the advantages offered by carbide, due to lack of rigidity and power at the spindle. The only real benefit is using carbide for hard or abrasive materials, where HSS may not offer the necessary wear resistance. I'm not trying to judge your machine in this instance, but it's something you should do in order to ascertain that you are truly benefitting by the use of carbide. If you have a fractional horsepower motor on the spindle, it's highly unlikely you are benefitting at all----made obvious by the fact that you're not achieving your goal--that of machining.
In your first post you made a comment that is troubling. There was some mention of the tool being parallel to the face. That's never acceptable. When machining, the contact of the tool should be limited---for the greater the amount in contact, the greater the chance of chatter. That's the reason form tools perform poorly on small machines. So then, if the tool contacts the entire face of the part as you feed in, you should expect trouble. A few degrees of clearance is always a good idea. Relocate the tool so only the tip makes contact, then give the setup another try.
I took note of the comments to Pix---that the chuck is new. Most likely it's not sprung. You may simply be asking too much from a small machine. Such machines are not generally up to the task of running carbide to its ability.
