RAMCO TK380 Collet Assy Removal
mcman56
Post by mcman56 »
I need to remove the 5C collet mounting assembly from a TK380 to mount a 3 jaw chuck. The back part is easy. I lift a pin and the tube with tightening assy slide right out. However, there is a nose piece that the collet sits in on the other end. How does it come off?
Re: RAMCO TK380 Collet Assy Removal
Post by GlennW »
It most likely fits into the spindle taper.
You may be able to tap it out using an aluminum rod through the spindle bore.
I use a bearing splitter to pop mine out as I'm not real wild about hammering against spindle bearings.
Splitter and 5C adapter
mcman56
Post by mcman56 »
It took just the lightest tap from behind.
Thanks!
alyons
Post by alyons »
Hello, I just joined the group. Do you know where I could find a manual for the Ramco TK380 Lathe?
