Hello all, and Jet 1236PS 1236-PS
Needcoffee
Re: Hello all, and Jet 1236PS 1236-PS
Post by Needcoffee »
swatson144 wrote:I converted mine to 3 phase via a vfd and am loving it. with the baldor motor it no longer bounces and the speed stays consistent. Plus the fact that it is variable and I can really get it slow for those coarse thread jobs.
Anyone looking for the manual it is posted above beside the green avatar like this message has.
Would you mind sharing a picture of the Baldor motor you installed. Maybe a shot of the dataplate with the frame size etc....
Thanks in advance
swatson144
Post by swatson144 »
I could and would gladly but it wasn't an exact fit and required a me to modify the base plate on the machine. I bought it as a really good deal on ebay.
Downwindtracker2
Post by Downwindtracker2 »
I haven't run my DF 1224g yet, but the Baldor 2hp bolted right in. Wiring. It's a 56/56H frame. However the two step sheave on the Taiwanese motor had a 3/4" shaft, whereas the Baldor was the much more common 5/8" requiring a to make up a new sheave. I used two cast iron hub ones and milled off the hub and bolted together.
swatson144
Since I was going 3 phase with a VFD I didn't bother with the double pulley and just put a single the same size as the most worn AL pulley. It's never been a problem.The motor I bought was an oddball I can't remember the frame size but it was longer and smaller diameter.
