Lathe Mounting
Lathe Mounting
Hello, seeking advice on mounting a Craftsman 12X42" bench lathe. currently mounted to a 1/4 " metal bench but seems to vibrate at higher speeds. Would a thick plate as a base bench top serve as a stiffener for the lathe?
Re: Lathe Mounting
I would tend to think that imbalance would produce vibrations more than lack of stiffness in the bench top.
What kind of "higher speeds" are you talking about?
Possibly beyond the capabilities of a Craftsman 12 x 42?
Re: Lathe Mounting
The vibration trends to come through the belt drive motor set up that hangs off the back of the lathe. I have installed a link belt and that helps. Just seems to carry out to the bedway more than I prefer. Am wondering if heavy base would add stability to the set up.
Re: Lathe Mounting
A thicker table would help but finding the source of vibration would be better. Try tightening the belt a little if it is causing the vibration. This isn't the machine that was for sale in Paris, TX last week is it?
Re: Lathe Mounting
I would have thought the link belt would cause MORE vibrations.
Re: Lathe Mounting
flute, I was surprised too. But, amazingly they do reduce vibrations some and handle smaller dia. pulleys too.
Re: Lathe Mounting
I guess if the belt speed is held down it would. First I would check for a lumpy belt, next a bent shaft or shafts and third bent pulleys.stevec wrote:flute, I was surprised too. But, amazingly they do reduce vibrations some and handle smaller dia. pulleys too.
Re: Lathe Mounting
Thanks, I will try your suggestion.
Re: Lathe Mounting
Eh......... a 1/4" top is a drum head...... yeah you shouldn't have vibrations just in general, but the top is thin regardless.
Yes, a thicker top will reinforce the machine to some degree. If you search over at the HSM site, a fellow posting as "artfulbodger" just had a concrete bench made. I don't know if he has any data on before and after, but evidence from other sources suggests that a very rigid base does wonders.
If it was me, I'd put two layers of 3/4" ply under that top. Glue the layers together, and bolt through with the mounting bolts, using a generous sized washer and plate underneath the ply on each mounting bolt. A couple screws or bolts through the top into it elsewhere will also help.
If you have excess vibration, it will still be there, but that should take care of the "drumhead" effect if the bench is reasonably close to the lathe size..
Re: Lathe Mounting
the linkes some call them segmented, smooth thing out because of increased flexability
i use them where ever i can and keep a legenth as a universal backup. it fits most legenths
hi hi
hi hi
Re: Lathe Mounting
My concrete machine bench is a great success in every respect.
