Machining a pulley
Moderators: Harold_V, GlennW
davec43
Re: Machining a pulley
Post by davec43 » Thu Mar 08, 2012 3:04 pm
Russ Hanscom wrote:Nice work on the soft jaws, but they were meant to be cut up! You can also buy them for a reasonable cost, or weld on material after they are pretty well cut away.
Thanks Russ, they are cut up now. They are for a Grizzly chuck G9819. Not the chuck I really wanted but budgetary restraints were imposed. I don't think I have seen soft jaws available anywhere with that configuration on the mating surface.
Dave C
Grizzly 12x36 lathe, Gorton 1-22 milling machine
davec43
Post by davec43 » Thu Mar 08, 2012 3:09 pm
Maybe that is a std configuration that Enco carries.
http://www.use-enco.com/CGI/INSRIT?PART ... A=325-1458
I'll have to check it out.
Dave C
Russ Hanscom
Post by Russ Hanscom » Thu Mar 08, 2012 9:13 pm
My soft jaws have the same configuration and it appears to be standard. Just look under Amercican standard soft jaws.
