The Home Machinist!
A site dedicated to enthusiasts of all skill levels and disciplines of the metalworking hobby.
It is currently Wed May 22, 2013 12:14 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3  Next
Author Message
PostPosted: Tue May 08, 2012 8:30 pm
Offline
WD-40 on the file will help prevent sticking the aluminum in the teeth, just as it helps when turning. As mentioned, the file card is your best friend on this job.
There are special files for lathe filing. The teeth are at a much greater angle than those on a mill bastard. This helps to shear off the material. I have a 12" Simmons that has LATHE stamped right on it by the trademark.
--earlgo
Top
 Profile
PostPosted: Tue May 08, 2012 8:41 pm
Offline
Can someone elaborate on the file card and cleaning files? I've thought I've ruined some by flattening the edges but maybe they are just plugged.
_________________
Logan 10x24 Lathe, RF-30 Mill, 20 Ton Press
Top
 Profile
PostPosted: Tue May 08, 2012 9:39 pm
Offline
The file card works OK, but to really clean a mill file, I prefer taping some aluminum sheet to a putty knife. Push it in the direction of the grooves in the file and the aluminum will conform to the file pattern and clean everything out righ down to the roots.
Some do the same using a slice of hardwood.
Using chalk will keep it pretty clean.
_________________
Top
 Profile
PostPosted: Tue May 08, 2012 11:40 pm
Offline
If you've used the file card like a brush, working front to back on the teeth, that's a mistake. File cards have heat treated wire teeth that are very capable of destroying the cutting edges of files. Some folks insist they shouldn't even be used.
To use one with minimum damage, to both the file card and the file, draw the file card parallel to the teeth of the file. Don't push! The offset of the teeth is intended to dig in to the file, to remove pinning. If you push, the teeth float over the material and gradually lay down, never to stand up again.
You are well served to follow the lead both Glenn and I provided---using a thin piece of metal, parallel to the teeth. It's' faster, works better, and doesn't harm the teeth.
_________________
Top
 Profile
PostPosted: Wed May 09, 2012 7:45 am
Offline
Apparently Bamboo can be used instead of aluminum or other "softish" metal. I've yet to try it myself, I'm waiting for the Pandas to leave before I cut some bamboo. :lol:
Top
 Profile
PostPosted: Wed May 09, 2012 2:21 pm
Offline
Might giver 'er a try this weekend on some smaller stock. Will try doing it by hand with the cutting tools and gradual feed (how to say that? In other words, I'll try an HSS tool in the holder and use the dials to work it). No free handing with the files just yet.
_________________
You never know what your faith is until your faith has truely been tested.
Top
 Profile
PostPosted: Wed May 09, 2012 3:41 pm
Offline
A piece of hardwood can be used, too, but if the pinning has attitude, it just removes the wood instead. That's why a piece of metal is more desirable. You can see how well the piece of aluminum works for Glenn-----results I get are the same from the titanium I use. Aluminum is far more readily available. I lucked in to the piece of titanium, which is rigid enough that it needs no further support. I'm not promoting its use---just suggesting that if you happen to have some available, it works well.
_________________
Top
 Profile
PostPosted: Wed May 09, 2012 5:00 pm
Offline
Titanium, Aluminum, hard wood, bamboo all works.
I flattened a 1/2" copper pipe on end and soldered a cap on the other, drill a hole radially to hang, presto a round handle and a flat soft metal edge.
Not yet found a subborn enough pin that could not clean out.
_________________
Top
 Profile
PostPosted: Wed May 09, 2012 7:08 pm
Offline
I use an piece of 357 Magnum brass, hammered flat on the open end and annealed, with the primer end jammed into a worn out (drilled to press fit) file handle. Readily takes the set of the teeth like a really stiff coarse brass brush. Works great and allows "focus" on problem areas when they arise.
_________________
Top
 Profile
PostPosted: Wed May 09, 2012 8:01 pm
Offline
Just give the file to the Pandas and let them clean it!
_________________
Top
 Profile
PostPosted: Wed May 09, 2012 10:22 pm
Offline
Glen and Harold,
Another day, another lesson learned. :D :D
Jack.
Top
 Profile
PostPosted: Thu May 10, 2012 10:28 am
Offline
BadDog, did you remove the charge before hammering that 357 Magnum flat?
_________________
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Google Adsense [Bot] and 3 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
Powered by phpBB® Forum Software © phpBB Group
