H&G Die Heads
JimB
H&G Die Heads
Post by JimB »
I have just aquired 3 H&G die heads, 101 DM, 102 DM, and 103 DM. Where can I find operating manuals, and setup instructions?
Thanks JimB
Re: H&G Die Heads
Post by GlennW »
Welcome to the group!
A quick Google search turned up this.
http://www.internationalscrew.com/pages ... _and_g.htm
http://www.qualitychaser.com/qc_ordin.html
http://www.qualitychaser.com/index.html
...as well as a bunch of other info.
I imagine that they may be able to help you.
JimB
Re: H&G Die Heads
Post by JimB »
Thanks Glenn
I just sent a e-mail to internationalscrew.com. To see if they had a Maunal
I have looked at all the sites on google, including the patent database. found several patens but no operating or setup info.
JimB
Re: H&G Die Heads
Post by JimB »
I just recieved a reply from internationalscrew.com, they sent a pdf of the operating manual. it is a little blured but useable.
It has operating and setup instructions for all DM heaads.
If any one needs a copy pm me.
rcl4144
Re: H&G Die Heads
Post by rcl4144 »
Hi JimB...If you still have a copy of the operating manual for all H&G DM heads I could purly use a copy " reli.consulting@gmail.com "
Regards Roger
