Atlas crossfeed and compound nuts
My acquaintance Tom Ross in Nebraska makes these nuts to original specifications and they work very well. So if you need a replacement, this is the place to go.
This picture is for the cross feed nut for the Atlas 12" lathe P/N 537-041. He also can make the compound nut P/N 537-040.
His contact info is TRoss96586@aol.com
Just FYI.
--earlgo
