I have a Logan 11" with quick -change gearing. It always did a great job cutting threads. Then, I swapped the 24 and 48-tooth stud gears to cut 6 tpi. Well, it didn't match up with the thread I was trying to recut, but I figured the piece I was working on might have gotten stretched in use.
I found a different usable part and changed the lathe gears back to what they had been. But it still doesn't cut the selected thread pitch. When 8 tpi is selected, it cuts exactly 10 tpi. When 16 tpi is selected, it cuts exactly 20 tpi.
I have the 24 tooth stud gear driving the idler, 80 tooth on the screw, and 8 tpi selected with the change gears.
How can this be? What have I done?
Jim Davis
Threading puzzle with Logan quick-change
Re: Threading puzzle with Logan quick-change
I will write a formula to illustrate the problem:
First, your 80T screw gear produces 10 TPI, but you want something (x) to produce 8 TPI
80/10 = x/8
8 = x/8
x = 8 * 8
I think the screw gear should be a 64T
My 10" Logan has a 72T on the "screw" (or input to the QCGB), but I also had an extra 64T and 48T that came with the lathe (used).
80/10 = x/8
8 = x/8
x = 8 * 8
I think ctwo has it right. Did you by any chance mix up the idler and screw gears?
Don Young
- Location: The Warm Arizona Deserts... Phoenix to be precise...
Looking at a Logan 820 gear change chart
The three gears to do a 8tpi are
32 stud
72 idler
32 screw
32 stud
72 idler
32 screw
