Millrite vertical mill
Moderators: Harold_V, GlennW
wlw-19958
Re: Millrite vertical mill
Post by wlw-19958 » Sun Nov 25, 2012 12:50 pm
Hi There,
jcbrock wrote:It probably varies an inch or two depending on the motor.
Also, whether there is a 5" or 6" riser under the turret.
Good Luck!
-Blue Chips-
Webb
jcbrock
Post by jcbrock » Sun Nov 25, 2012 8:06 pm
71" with no riser in my case, and also that is from the bottom of the base to the top of the motor case, no floor mounts included. An additional consideration is the headroom to pull the drawbar if you need to, although you could rotate the head to the side to do that.
John Brock
wlw-19958
Post by wlw-19958 » Mon Nov 26, 2012 10:06 am
Hi There,
jcbrock wrote:An additional consideration is the headroom to pull the drawbar if you need to, although you could rotate the head to the side to do that.
You can also lower the quill to gain a little more room for
withdrawing the drawbar. Tilting the headstock will work
of course put re-tramming the head just for that would be
a pain IMHO.
My Millrite is somewhere near 7 feet in over-all height when
you add the riser and have one of the geared-down motors.
Good Luck!
-Blue Chips-
Webb
Tamper84
Post by Tamper84 » Mon Nov 26, 2012 10:13 am
That is a nice looking mill!! How hard was it to add the dro to it?
Thanks,
Chris
