Newbie q`s
- SteveHGraham
Re: Newbie q`s
When I mentioned alcohol here, people complained about the fire risk, but if you think about it, the fire from one cc of alcohol is not likely to do much harm.
- warmstrong1955
Re: Newbie q`s
SteveHGraham wrote:When I mentioned alcohol here, people complained about the fire risk, but if you think about it, the fire from one cc of alcohol is not likely to do much harm.
Ohhhhhhh.....that kind of alcohol......
Kind I was thinkin' of shouldn't be used until after the project is completed.
Bill
Re: Newbie q`s
You didn't say if you did it all in one cut or had a rough and light finish cut. If you did it all with one cut then you may be seeing the result of the end mill being deflected to one side from the cutting forces.Jorgens wrote:Hi again.
As I am messing around with the mill, I have tried to do a surface job on a alublock with a Ø16 endmill.
I can feel some small "grooves" alongside the direction of the way I milled it-why doesn`t the surface become completely smooth?
I did a offset of 10 mm between every cut. The head is adjusted plane to the table. Is there a thumb rule of how much i should overlap?
I was running @ 1900 rpm`s and sloow feed.
Jørgen
I generally over lap about 2/3 of the cutter diameter. I use a fly cutter for flat work that has a 3/4" shank and uses a 1/2" tool.
Richard W.
Re: Newbie q`s
Have you found this to be relevant for aluminum?stevec wrote:I don't use WD40 for anything, it has some water displacing characteristics one of which is to absorb water. If left on metal long enough for the chemicals to evaporate the water remains and can actually cause rust.
Re: Newbie q`s
No oldvan, I don't find it relevant for aluminum, nor do I have any aluminum machine tools.
Re: Newbie q`s
I did it in 1 cut- approx 2/10 mm. 2/3 of the diameter, thanks, I`ll give it a try next time!Richard_W wrote:You didn't say if you did it all in one cut or had a rough and light finish cut. If you did it all with one cut then you may be seeing the result of the end mill being deflected to one side from the cutting forces.Jorgens wrote:Hi again.
Jørgen
Richard W.
Jørgen
