I have restored antique electric fans for about 20 years and have decided it is time for a small mill to reproduce some parts needed. My first project will be on a 3/8 diameter shaft 3 inches long. I need to reduce 2" on the end of the shaft to .359 diameter.
I would appreciate ideas on how best to accomplish this on a vertical mill.
Dan
Mill project help needed
- SteveHGraham
Re: Mill project help needed
I would use a lathe. Just chuck the shaft and turn it to a smaller diameter by moving the cutter toward the headstock.
On a mill, you could use a rotary table with a chuck. The cut you're doing is long; if it were short, you could mount the shaft upright and use a straight end mill to cut into the diameter as you turn. With a long cut, you could mount the table on its side with the shaft horizontal and lower an end mill onto it.
I would chuck the shaft verticals then use a borringng head to reduce the shaft size. Turn the cutter inward and you are off and running.
Chuck the3/8 stock in a collet and hold a lathe cutter in the milling vice. Feed the stock up and down with the quill and the cutter in with the table.
Thought I'd try it here when making a gear cutter mandrel. Got virtually zero runout.
https://lh4.googleusercontent.com/-PkT3 ... G_0920.jpg
Greg
Greg
Greg's right on with this one. sometimes you gotta think outta the box.......
Thanks to all of you for your help. I really appreciate it.
Dan
Dan
I think, if you have not bought the mill yet and are just kind of working things out, I would consider a lathe first. Especially if shafts and bushings, might be what you are after, for the fans. Light weight milling can be done on a lathe, if necessary.
Live for the moment!
Prepare for tomorrow!
Forgive the past!
Forgive the past!
